Pitch Shifter - Jemsite
post #1 of 2 (permalink) Old 06-27-2010, 01:54 AM Thread Starter
Pitch Shifter
Hey guys, I just aquired an old pitch shifter (Digitech 33B) and I am wondering exactly where in the loop do I put the pitch shifter? Before or after my G-Major?
Thx
Kev
kpinks is offline
post #2 of 2 (permalink) Old 06-27-2010, 10:55 AM
Re: Pitch Shifter
Pitch shifters don't like to be put after distortion or effects, even non-intelligent shifters.
Especially older ones will have trouble tracking.
Some have a separate (clean) input so they can pitch shift very distorted/effected signals, but that does not apply to the 33B iirc.
The trouble is that if you do the shifting pre-distortion, you are going to distort the shifted signal which might or might not work with the distortion you're using and will also depend on the interval you're shifting (just try to play heavily distorted diads in 5ths, octaves, Maj3rds, min3rds, 4ths etc.) If I'm not mistaken the 33B could have a whammy function (depending on firmware) which is typically put in front of distortion, otherwise leading to very lo-fi shifting.
Does the G-Major have a loop?
eviltwin is offline
pitch shifter
FS: BOSS PS-5 Pitch shifter sirshredsalot Classified Ads: Guitars and Gear 1 04-23-2010 02:46 PM
If you need a pitch shifter... 6fingers Gear, Equipment, Recording & Off Topic 0 11-01-2009 02:06 PM
FS: Rocktron Intellipitch (Intelligent Pitch Shifter) VERY RARE! revsharp777 Classified Ads: Guitars and Gear 2 06-09-2006 08:31 PM
Best pitch shifter/harmonist? Drache713 Gear, Equipment, Recording & Off Topic 20 01-28-2003 01:35 AM
Anyone have a manual for a Digitech IPS33 pitch shifter? bduersch Gear, Equipment, Recording & Off Topic 4 12-05-2002 05:34 PM
