Placing effects. Is it right? - Jemsite
post #1 of 10 (permalink) Old 01-07-2003, 02:38 PM Thread Starter
Ive two new pedals for Christmas, and im not completely sure of how to position them. They are(all my gear):
- Boss DS1 (used as booster)
- Mesa Bottle Rocket (tube overdrive/disto).
- Bad Horsie 2 wah.
- Korg A3 Multi FX.
- Boss Noise Supressor NS2.
Im using it: Bad Horsie-->Ds1 --> Bottle Rocket --> A3 --> NS2. Is it ok?
Thanx.
Urko.
urkoman is offline
post #2 of 10 (permalink) Old 01-07-2003, 02:53 PM
Does your amp have an effects loop?
Out,
GP
pri0531 is offline
post #3 of 10 (permalink) Old 01-07-2003, 07:48 PM Thread Starter
Nop, but the NS2 does. Ive tried this:
Bad horsie-->NS2 --> Amp, and in the NS2 the ds1--> B. Rocket -->A3 too.
urkoman is offline
post #4 of 10 (permalink) Old 01-07-2003, 10:47 PM
OME
Reviews: 6
I've read where it is good to place your NS2 (gates) airectly after
your distortion box, 'cause that's where the most unwanted noise comes from. That way you still get all the delays n FX you need.
OME is offline
post #5 of 10 (permalink) Old 01-08-2003, 03:02 AM
i would put the DS1 and the Rocket in the NS2's FX loop.
nuno is offline
post #6 of 10 (permalink) Old 01-10-2003, 03:45 PM
I would go this route :
Guitar---> Bad Horsey->NS-2 input then from the NS-2's send into the DS-1--> mesa--NS-2 Return, then Ns-2 Output--> Korg, korg into your power amp or amp.
You'll want to quiet the distortion's hiss before adding echo and reverb to it, so that makes the most sense. Also experiment with putting the DS-1 before the NS since you're using it for lead boost. Odds are you'll turn it off immediately after soloing. Also experiment with swapping the order of each distortion, one may sound better at the front of the signal chain that the other.
Let us know what you do and how it sounds !
Bamm
bammbamm is offline
post #7 of 10 (permalink) Old 01-10-2003, 04:30 PM
OME
Reviews: 6
Bamm
I've alwayz said if you got a good soundman at the board let him do the boost. Hehe, maybe that's just a Kirk Hammett thing though
OME is offline
post #8 of 10 (permalink) Old 01-10-2003, 04:40 PM
Thats a BIG if....
Especially if he's never worked with you before.
I always have my lead signals dialed in to boost 1 and 2K freq.'s around +3 db just for leads. I never count on the soundman unless he's someone I've worked with and he knows the songs.
Bamm
bammbamm is offline
post #9 of 10 (permalink) Old 01-10-2003, 05:20 PM Thread Starter
Thanks Bamm!!!Ill try avery possibility tomoroow (this week has been a sh+t, worked 12 hours every day). News tomorrow.
urkoman is offline
post #10 of 10 (permalink) Old 01-11-2003, 11:16 AM Thread Starter
Its done. Sounds the best when its BHII-->NS2--->DS!--->A3 and the mesa in the NS2 loop. Anyway, im seriousky thinking about selling the DS1. Gives nothing to my sound now i have the mesa.
urkoman is offline
kirk hammet , kirk hammett , power amp
Wah placing Maverick1076 Gear, Equipment, Recording & Off Topic 7 06-05-2010 07:51 PM
A total disaster while placing my tshirt post nikster Off-topic / Miscellaneous 4 07-01-2009 01:17 AM
FS: Effects, MIDI, 10 Space Effects Rack geetarmonkey Classified Ads: Guitars and Gear 2 12-12-2006 02:27 PM
Gear setups - effects or no effects? Shredder87 Gear, Equipment, Recording & Off Topic 25 05-24-2006 09:07 AM
placing d-sonic InSaNe sHRed Ibanez JEM, UV, JS & Other Signature Models 10 03-26-2006 09:10 PM
