Pod into Legacy (efx return) - Sounds very tight and easy to - Jemsite
post #1 of 4 (permalink) Old 02-21-2002, 10:45 PM Thread Starter
I have always liked the Pod (2.0) but it sounded bright and shrilly when cranked through a power amp. *I tried running it into the front of the Legacy but it didn't sound so GREAT. * Then I tried it into the return, still just ok. *Then I ran it throught a Rocktron Multivalve then ito the Legacy return. Now I'm happy. *I can use the multivalve to EQ the POD before it hits the power amp/Legacy. *We all know the Legacy has big semi smooth tone crancked, but at reasonable levels, it's a little tough to get all the smooth gain you want for lead playing. *
*I've also done this, run the DS-1 into the lead channel with Vai's settings. with a comp pedal. Didn't like it. *I did however like the DS-1 into the clean channel, and I used an overdrive pedal infront of that to get a little mors gain, because I had the DS-1 setr for "crunch". *That sounded good, also using the Multivalve as an EQ in the loop.
But I wanted somethin a little "tighter", more like Petrucci. *The POD so far gives me that. *
Oh, I put an Evolution in my VDY Jem, WAY BIG difference over the PAF (?). *And I just got my NEW PRS custom guitar with ChromeIllusion paint, Ebony fret board and Dragon 1's, coil tap 3 way. *Very sweet.
It cleans up better than all my other guitars when rolling the volume back on the Lead channel. *
Has anyone else had success with their POD?
Darin
Darin W is offline
post #2 of 4 (permalink) Old 02-21-2002, 11:24 PM
I've been doing a lot of direct-recording with my POD lately. *Now matter how much I tweak the knobs, i was still very unhappy with its sound. *But after using the graphic eq on my Cakewalk, the sound improved dramatically and I was happy
When I get a real amp, maybe I'll do the same thing you did. *It sounds like a cool idea.
Carlo is offline
post #3 of 4 (permalink) Old 02-22-2002, 12:33 AM
Woah.. what I want to know is how much a custom PRS cost you.
Kremlin is offline
post #4 of 4 (permalink) Old 02-22-2002, 01:18 AM Thread Starter
The price is in the $3,900 range. *But worth every penny. *
Darin
Darin W is offline
coil tap , custom guitar , ebony fret board , fret board , overdrive pedal , power amp
Any reason to get a legacy 1 combo over a legacy 3 half stack? Archlute Gear, Equipment, Recording & Off Topic 8 10-07-2013 01:11 PM
The Return of..... vaijem777 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 7 05-17-2006 04:46 PM
Return To My Jem tak Ibanez JEM, UV, JS & Other Signature Models 0 05-11-2005 12:54 AM
Legacy sounds Praetorian Gear, Equipment, Recording & Off Topic 3 08-30-2004 04:07 AM
Carvin Legacy? - Example of what it sounds like? Kremlin Gear, Equipment, Recording & Off Topic 7 10-23-2001 12:03 AM
