pro tool newb ?'s again :( - Jemsite
post #1 of 6 (permalink) Old 08-30-2007, 08:13 PM Thread Starter
Unhappy pro tool newb ?'s again :(
ok here are a few questions i have gathered
what is the best way to hook up an electric guitar to an mbox?
why is it when i plug my m audio keyboard into my mbp and play and have analog factory open and dialed in it dosent record (shows thhe input but no sound {midi instrument})
how do i open plugins that i have in pro tools?
KyleChx is offline
post #2 of 6 (permalink) Old 08-30-2007, 09:15 PM
Re: pro tool newb ?'s again :(
1) You should be able to plug your guitar directly into the Mbox mic ins - use Amplitude LE to get a decent guitar tone, or use your amp rec outs/pod whatever before the Mbox
2) I don't know, but you DO have to click on the little red button on the selected track's info area to record enable the track
3) On the selected track -look in the table called "inserts" - there should be five little boxes with an up and down arrow on them - hold/click on this and the RTAS plug ins open up. Alternately, if you want to make a permanent effect change to a track (say you really know you want flanger on some guitar track), you can select the track, go to the Audiosuite pull down menu and select the effect you want, and process the track directly - this is only undoable by deleting the track and retrieving the uneffected track from the audio pool, whereas inserts are like stompboxes, you can adjust them, bypass them, replace them etc etc as you go.
Sorry if this all sounds pretty technical, but I can't think of simpler ways to explain - if I remember I'll grab some screenshots this weekend and post them for you.
Cheers, and good luck with it!
David
David McCarroll is offline
post #3 of 6 (permalink) Old 08-30-2007, 11:54 PM Thread Starter
just wanted to say thanks for the input
KyleChx is offline
post #4 of 6 (permalink) Old 08-31-2007, 12:18 AM
S'okay - hope it is of some use to you - PM me and remind me to take some screen shots of the above operations - might help you see what I am talking about.
Have a great weekend,
David
post #5 of 6 (permalink) Old 08-31-2007, 02:18 PM
Again I'll give you a book that a Pro Tools beta tester/engineer friend of mine wrote. Its the best PT book IMHO... His name is J Franze and the book is pro tools a-z. good luck.
Ibanut is offline
post #6 of 6 (permalink) Old 09-01-2007, 02:14 PM Thread Starter
sweet i found it for sale on a few sites... ill pick it up durin the week
thanks
KyleChx is offline
electric guitar
Edge Pro 7 tool Allen Garrow All Other Guitars (including Prestige) 3 05-15-2005 11:11 AM
Lo Pro Edge intonation tool... Bluestreak Tech: Setup, Repairs and Mods 4 02-01-2005 03:26 PM
tool to remove the trem post set screws schmintan Tech: Setup, Repairs and Mods 2 02-05-2003 01:09 PM
Allparts Intonation Tool for an Ibanez Lo-pro pri0531 Tech: Setup, Repairs and Mods 7 12-18-2002 12:32 PM
Tool is coming to Denver: I'm going, but I need tickets :( Superuser Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 07-19-2002 04:06 PM
