Pro Tools Plug in set up - Jemsite
post #1 of 7 (permalink) Old 06-08-2006, 09:12 AM Thread Starter
Reviews: 13
Question Pro Tools Plug in set up
Does anybody know how to set up the plug in for pro tools? I have the audiosuite plug in however I can get my Amplitube and BFD plug ins working.
Wolfram
Wolfram is offline
post #2 of 7 (permalink) Old 06-08-2006, 11:00 AM
Re: Pro Tools Plug in set up
open the mixer window and at the top of the channel strip there is are two small arrows up &down. Thats your inserts click there and you'll see the plugins there. The next area down is your aux sends. thats how you create a send for time based EFX.
Ibanut is offline
post #3 of 7 (permalink) Old 06-09-2006, 09:08 AM Thread Starter
Reviews: 13
I have four sets of the arrow things and when I click on one of the I get three options No send, interface and Bus. The option for Plug ins is ghosted. Could it be a problem with the way I installed them? I just ran the disks and clicked finish at the end. Is there anything else I need to do to enable them? I have the Ilok key etc. Thanks Wolfram
Wolfram is offline
post #4 of 7 (permalink) Old 06-09-2006, 09:56 AM Thread Starter
Reviews: 13
Finally! I hadn't opened up a tab on the bottom of the screen.
Now the next question is how do I actually import the drum sounds into a track?
Wolfram is offline
post #5 of 7 (permalink) Old 06-11-2006, 03:49 PM
There is a import to track option in a pull down window. The send bus option is for setting up a EFX send return or to bus that track to another. In the mix window above the send return there should be another pull down. Thats your inserts. Thats where the plug ins should show up also. Did you order that PT book yet? Also if your drums are midi then you can open up a midi track in PT
Ibanut is offline
post #6 of 7 (permalink) Old 06-23-2006, 07:34 PM
Where did you get your pro tools?
which version is it? I need that program but it as Ilok safety...I can't instal it....how did you get it?
Thanks...sorry to go off topic
BLAKK:JAKK
BLAKK:JAKK is offline
post #7 of 7 (permalink) Old 06-23-2006, 07:55 PM
You have to buy digidesign hardware to operate PT software. I have an MBOX, you can also get A pro tools compatible Maudio interface and get the software. Digi did this to prevent piracy. I have version 6.7 and plan to upgrade to 7.1 soon
Ibanut is offline
audio interface
buying reconditioned tools, worth it? SilverSurfer2 Off-topic / Miscellaneous 2 08-18-2005 02:18 PM
Shorting plug for Mesa 20/20 steeda Gear, Equipment, Recording & Off Topic 0 07-07-2005 08:10 PM
Intonation Tools guam-jem Tech: Setup, Repairs and Mods 0 03-18-2005 06:03 PM
set up tools whyerd Tech: Setup, Repairs and Mods 3 12-08-2002 04:45 AM
Pro Tools Free - An Update bob oakman Gear, Equipment, Recording & Off Topic 21 12-19-2000 11:55 AM
