Problem with Bad Horsie - Jemsite
post #1 of 10 (permalink) Old 12-28-2002, 02:27 PM Thread Starter
I bought a Morley Bad Horsie wah pedal a couple of weeks ago, and it nearly changed my life. It's got a really sweet wah sound, and I loved how I didn't have to damn near push the thing through the stage to get it on and off. It's been a dream come true until last night at a gig. I did a solo using the Morley and when I took my foot off the pedal, the light stayed on and I couldn't get it to shut off. The unit is new and I don't understand what's wrong. I've put a brand new battery in it, and I've tried everything I can think of to get this pedal back but it just won't cooperate. As soon as you plug into it, the light goes on and stays on.
Now I know this is probably a common problem for these pedals, and I need you guys to help me. Tell me how to fix it!!!!
Rockstar is offline
post #2 of 10 (permalink) Old 12-28-2002, 04:28 PM
Is there some piece of crap stuck under the heel of the pedal that prevents it from returning all the way? You can also tweak the "stays on time" internally. Maybe that's whacked. See your instructions.....
FWIW,
-bill
wyldbill is offline
post #3 of 10 (permalink) Old 12-28-2002, 05:41 PM Thread Starter
Oh ok....I pulled up on the toe kinda hard and the light goes out. But as soon as I step on it, it stays on. I've gotta get some documentation on this thing and take a closer look. Thanks WyldBill
Rockstar is offline
post #4 of 10 (permalink) Old 12-28-2002, 06:59 PM
Someone else mentioned that the little rubber feet under the back of the pedal sometimes block it from going all the way back. If there's a way to adjust the effective range, go for that, but otherwise, remove or shave down those feet. Anything to get it to rock back farther.
Two hands31 is offline
post #5 of 10 (permalink) Old 12-28-2002, 07:52 PM
Yeah, that was my problem, too. The whole staying on thing...no luck yet, but I'm working on it. Sounds like a common thing!
AdamBilz is offline
post #6 of 10 (permalink) Old 12-28-2002, 08:00 PM
Did you even bother to read my reply?
post #7 of 10 (permalink) Old 12-28-2002, 10:49 PM
Or you could see if anything is wrong wiht the plastic piece inside that stops the laser beam from reflecting to the other side.
Jeff is offline
post #8 of 10 (permalink) Old 12-28-2002, 11:36 PM
Sorry dude, I'm just fed up that two pedals have just given up on me. None of those tricks worked for mine, it's quite frustrating having to use an old Crybaby when one comes to love the smoothness and ease of the BH. Thanks anyway.
AdamBilz is offline
post #9 of 10 (permalink) Old 12-29-2002, 12:10 AM
Ah, well you shoulda mentioned that. No harm done. I have a similar problem with my Line6 Floorboard's volume pedal, it's never completely silent unless I really push down on the back end. My old Korg AX-1G had the same problem, but it was easily adjustable, so that was quickly fixed. I'll have to do some looking at my Floorboard.
post #10 of 10 (permalink) Old 01-06-2003, 01:37 PM Thread Starter
I pulled the little rubber feet of the underside of the heal part of the pedal.
Worked like a charm. Light goes out when I take my foot off! THAT WORKED!!! THANK YOU!!!!
Rockstar is offline
horsie wah , volume pedal , wah pedal
Bad horsie problem? fwd0120 Gear, Equipment, Recording & Off Topic 2 01-22-2012 09:31 PM
Morley Bad Horsie 2 problem AmazinAzian12 Tech: Setup, Repairs and Mods 9 03-13-2008 12:57 AM
FS: Morley Steve Vai Bad Horsie & Bad Horsie II Wah Pedals vaijem777 Classified Ads: Guitars and Gear 3 04-30-2007 12:32 PM
Bad Horsie or Bad horsie 2 contour? ll Mr Blonde ll Gear, Equipment, Recording & Off Topic 16 06-29-2006 02:42 PM
Bad horsie problem Fry Gear, Equipment, Recording & Off Topic 11 04-02-2004 05:31 PM
