Problems with Boss PS-6 Harmonist - Jemsite
post #1 of 9 (permalink) Old 07-26-2011, 02:08 PM Thread Starter
Question Problems with Boss PS-6 Harmonist
Just bought a Boss PS-6, when i use the Pitch Shifter or Harmonist mode the smooth lead medium gain sound turns muddy and gravely along with the original sound (similar to when you hold a full chord in harmony mode).
I'm using the unit in an effects chain but when i heard the problem i removed all the effects and just used the unit between the guitar and the amp and nothing changed. Before i go back to the shop looking like a bit of a prick, i'm using a non boss adaptor for the unit, the battery supllied was a cheapy (non duracell) and i also tried it with my adaptor i have with my roland microcube - as the harmony effect is a very strong one could it be that it needs a full strength battery or boss only adaptor or have any of the helpful jemsiters out there had similar problems with the PS-6 of earlier models (PS-5,HR-2).
Thanks
RGgreen is offline
post #2 of 9 (permalink) Old 07-27-2011, 02:47 PM
Reviews: 59
Re: Problems with Boss PS-6 Harmonist
I don't think a different adapter/battery is going to give you tonal differences unless you've been using an improper adapter or the battery is dying. Are you finding this problem across the board or only on very "wet" settings? If it drastically impacts your tone on drier settings, it could be you have a bad one and you might want to consider replacing it. If it's only a problem on the wet side of things, you might want to run it drier or adjust EQ to compensate.
The nature of these pedals is that they do have a significant impact on the tone. Sometimes it sounds great and you like it, however, a lot people (especially those going after very organic tones) hate what it does to their tone and only use it, if they use it at all, in select settings. You'll have to decide. I have the PS-5 and I use it when I'm going for really out there stuff, because it does really change the tone, much more metallic, much harsher. I like it for what I use it for and I don't expect it to maintain my tone transparently since it will never do that.
smooth55 is offline
post #3 of 9 (permalink) Old 07-28-2011, 01:43 AM Thread Starter
Thumbs up Re: Problems with Boss PS-6 Harmonist
Thanks for the reply, I'm going to take it back to the store and see if they get the same result as I do, if so get a replacement which I'll try before taking. I've listened to the demo sounds on various sites and the unit sounds great, it might be me misusing the unit, I'll post an outcome later today.
RGgreen is offline
post #4 of 9 (permalink) Old 07-28-2011, 06:13 PM
Reviews: 4
Is the first thing in the chain of your fx loop the ps-6? Might explain some of it.
fwd0120 is offline
post #5 of 9 (permalink) Old 07-29-2011, 06:03 AM
Harmonizers belong in the effects loop, or after a distortion pedal but before delay if you get all your distortion from a pedal. If you place it between your guitar and amp you'll get exactly the sound you describe.
Petie is offline
post #6 of 9 (permalink) Old 07-29-2011, 11:03 AM
I wouldn't imagine that the harmonizer would sound nice harmonising all that distorted fizz. My whammy sounds WAY better straight after my guitar. (even better with a clean boosted signal before it)
Toodles, Julz!
julzius is offline
post #7 of 9 (permalink) Old 07-29-2011, 05:43 PM
Reviews: 59
I put mine right after my tuner and wah, both of which are true bypass. I think they work better with as clean a signal as possible. To each his own, if it sounds better in your loop, go for it but I've always found it's best early in the chain.
smooth55 is offline
post #8 of 9 (permalink) Old 07-29-2011, 07:04 PM
Yarr effects like this should be early in the chain, it probably can't cope with the line level of the loop.
jeremyb is offline
post #9 of 9 (permalink) Old 12-24-2012, 01:33 PM
On the FX loop after the reverb and the delay. I tried all combos that i could possible imagine and thats we it sounds sweet to me !
REgards
joaquin.m.a is offline
roland boss
Boss DD-3 Delay Problems??? Axe Chemist Gear, Equipment, Recording & Off Topic 2 08-23-2008 03:10 PM
Anyone else had problems with Boss TU2 tuner? microdmitry Gear, Equipment, Recording & Off Topic 10 09-06-2004 04:18 PM
Rg 3120 Problems. ANNOYING PROBLEMS!!!! Given to Fly All Other Guitars (including Prestige) 20 05-24-2003 01:24 PM
Best pitch shifter/harmonist? Drache713 Gear, Equipment, Recording & Off Topic 20 01-28-2003 01:35 AM
Boss DD-3 problems - no delay ruby Tech: Setup, Repairs and Mods 3 02-10-2001 09:59 AM
