Pulldown Resistors for my DIY A/B Switcher - Jemsite
post #1 of 1 (permalink) Old 08-23-2012, 11:07 AM Thread Starter
Reviews: 23
Unhappy Pulldown Resistors for my DIY A/B Switcher
Hey guys, I have just recently gotten into building some pretty simple DIY stomps, namely, a Jack Orman design MOSFET Boost (http://www.muzique.com/schem/mosfet.htm) and a passive A/B line switcher. My current problem/issue concerns the A/B box.
My current pedalboard is set up like this:
guitar->A/B switcher-> [line A: Compressor->Chorus] [line B: Overdrive->Distortion] ->Delay->Boost->amp
At every given live playing situation, at least one pedal from either side of the switcher is kept on.
I have read on a DIY forum somewhere that in order to get rid of the popping sound I get from switching between the two signal loop chains, I have to solder 1Mohm pulldown resistors to ground on the respective loops' returns, and so I did. It did significantly reduce the popping, but not completely eliminate it. If left "bypassed" for too long one side will always manage to "charge up" and give a softer, but still bothering popping sound when I switch it in.
Should I reduce the resistor value to something like 500Kohms? Will this affect the signal integrity of my setup, considering that the parts of the A/B switcher circuit that have pulldown resistors always see an effected signal? Is there a better way to solve this popping issue? Please help a brother out!
theapprentice is offline
a/b switcher , diy , pedal , pop , pulldown resistor
Switcher help. toolguy Gear, Equipment, Recording & Off Topic 4 11-13-2008 07:41 AM
Switcher help. toolguy Gear, Equipment, Recording & Off Topic 1 11-12-2008 02:04 PM
Switcher help. toolguy Gear, Equipment, Recording & Off Topic 0 11-11-2008 10:07 PM
Channel switcher StevenMikel Gear, Equipment, Recording & Off Topic 2 03-19-2007 02:08 PM
I need help in choosing a switcher AngelOfDeath Gear, Equipment, Recording & Off Topic 1 06-25-2004 01:15 PM
