QSC or Crown Power Amp? - Jemsite
post #1 of 8 (permalink) Old 07-17-2003, 07:42 AM Thread Starter
I am creating a rack setup and I need advice about a power amp. I have a Pod Pro and am going to get a Furman Plus conditioner to run through a Mesa Rectifier half cab. I play hard rock/metal and want a power amp to deliver enough power but not cause my distortion to become mud. The cab is 140 watts at 8ohms. I don't have the cash for a Mesa tube power amp and triaxis, which is why I'm looking at the alternatives: QSC and Crown. Any advice would be greatly appreciated. Thanks.
atpspc is offline
post #2 of 8 (permalink) Old 07-17-2003, 12:25 PM
ScottB's Avatar
I used a Tube Works Mos Valve for a few years before going the head / cab route in my rig. They're solid state, but they are very warm sounding. I believe the model I had was 90 watts per side. I've seen them selling used for $200 on the auction site.
ScottB is offline
post #3 of 8 (permalink) Old 07-17-2003, 03:17 PM
If you can drop the coin on a Crown or QSC, you may want to hunt down a used Mesa 20/20, you can get em from $3-400 bux delivered and they are well worth the $$$.
Bamm
bammbamm is offline
post #4 of 8 (permalink) Old 07-17-2003, 04:00 PM
check out some VHT power amps the 2/50/2 kicks ass.
Mesa makes some good stuff - 20/20 they make a 50w one forget the name
Carvin has some dirt cheap stuff that Vai, Steve Morse and others use, never used one tho.
20/20 Pod PRO setup was at my local Sam Ash and it sounded great.
spencer096 is offline
post #5 of 8 (permalink) Old 07-17-2003, 05:22 PM
If you plan on playing at a fairly loud level, don't get the MosValve. They really turn to crap at high volume. At a medium volume they sound incredible. You need as much headroom as possible with Line 6 stuff so make sure you try out whatever amp you are considering at a decent volume.
kent is offline
post #6 of 8 (permalink) Old 07-17-2003, 05:43 PM
Get something with a high wattage for sure. My Line6 Flextone II sounds great, but at 60-watts, it starts to break up the lowest gain clean stuff when cranked on the headphone jack.
Two hands31 is offline
post #7 of 8 (permalink) Old 07-19-2003, 02:06 AM
kennydoe's Avatar
I have Ccrown AND QSC amps in my PA. I prefer the QSC - it's cleaner power and MUCH MUCH lighter.
~K
kennydoe is offline
post #8 of 8 (permalink) Old 07-19-2003, 10:26 AM
Originally Posted by kennydoe
I have Crown AND QSC amps in my PA. I prefer the QSC - it's cleaner power and MUCH MUCH lighter.
~K
I have both as well; QSC on top & Crown on subs. I don't think you can go wrong either way - great amps. But if you're buying new, I would look at Carvin as well - great value on most of their catalog.
JESTER700 is offline
mesa rectifier , pod pro , power amp , power amps , rack setup , sam ash , steve morse , tube power amp
Is it time for a fret level or re-crown? xXLinkageXx Tech: Setup, Repairs and Mods 24 03-08-2012 04:25 PM
level and crown a scalloped fretboard andrewgosline Tech: Setup, Repairs and Mods 1 02-20-2012 09:43 AM
My RG550 needs a refret/crown jbandy10 Tech: Setup, Repairs and Mods 4 11-10-2009 11:17 AM
HELP!!! Crown, Leveling, polishing etc.. Lefty Robb Tech: Setup, Repairs and Mods 2 07-02-2006 01:24 AM
Fret level/crown...DIY?? gkelm Tech: Setup, Repairs and Mods 9 11-22-2003 11:24 PM
