question regarding Behringer FCB1010 - Jemsite
post #1 of 17 (permalink) Old 10-30-2012, 10:02 AM Thread Starter
Question question regarding Behringer FCB1010
hi there!
i want to buy the Behringer FCB1010 midi footswitch so that i'll be able to contol cubase and podfarm on the computer ... the question is can i directly plug this footswitch to the computer (USB maybe??) or do i need an audio interface? if so i am thinking of buying the pod ux2 it should work with the footswitch right?
cheers!
RICHO is offline
post #2 of 17 (permalink) Old 10-30-2012, 10:10 AM
Reviews: 64
Re: question regarding Behringer FCB1010
It's a midi controller and not an audio controller.
Go to Behringer website and download its manual, it's not that difficult.
6fingers is offline
post #3 of 17 (permalink) Old 10-30-2012, 10:21 AM Thread Starter
i just need to know if i plugged the behringer to the pod ux2 then to the pc ... will i be able to contol cubase or not? ... this isnt in the manual
RICHO is offline
post #4 of 17 (permalink) Old 10-30-2012, 10:35 AM
Reviews: 64
Yes it is.
6fingers is offline
post #5 of 17 (permalink) Old 10-30-2012, 10:39 AM Thread Starter
well i cant find the answer that im looking for in the manual so i came here for help .... ! is it so hard to answer this question -.- ?
RICHO is offline
post #6 of 17 (permalink) Old 10-30-2012, 11:59 AM
As far as I remember it has no USB. So you have to have some MIDI interface that will take MIDI jack (I had Edirol audio interface). Some internal soundcards may have MIDI breakout cables...
adnecs is offline
post #7 of 17 (permalink) Old 10-30-2012, 12:10 PM
jb4674's Avatar
Reviews: 18
If you haven't bought the FCB1010, you might want to look at this instead:
http://www.x-tempo.com/store
the device is wireless and you can operate it away from your pc.
Jimmy
jb4674 is offline
post #8 of 17 (permalink) Old 10-30-2012, 12:15 PM Thread Starter
adnecs ... thanks!
jb4674 .... waw not bad ill make some research! but what i like abt the FCB is that it has 2 expression pedals and u can connect to to an actual amp if u want or can u connect this to an amp also?
RICHO is offline
post #9 of 17 (permalink) Old 10-30-2012, 12:47 PM
If you have a MIDI input on your PC or soundcard, you can plug it straight in. If not, a cheap MIDI to USB convertor from eBay does the job. That's what I use on my FCB.
Mark_McQ is offline
post #10 of 17 (permalink) Old 10-30-2012, 12:50 PM Thread Starter
even better! thanks a lot
RICHO is offline
post #11 of 17 (permalink) Old 10-30-2012, 01:03 PM
Reviews: 6
If you are using the Behringer FCB1010, then you needs something like a M-Audio Uno - 1-In/1-Out USB Bus-Powered MIDI Interface for you computer.
11racksfx is offline
post #12 of 17 (permalink) Old 11-09-2012, 09:55 AM Thread Starter
so i bought the M-Audio Uno and the behringer FCB1010 and tried to use it with pod farm but so far no luck ... when i click on Midi-Learn i can see the command showing up but it has no CC value ... and it doesnt work ... what should i do?
here is a picture of what im talking about:
http://imageshack.us/f/713/podfarm.png/
and it would be awesome if someone could tell me how to use the fcb to control pod farm in cubase! i really neeeeeed that
RICHO is offline
post #13 of 17 (permalink) Old 11-10-2012, 08:12 AM
jb4674's Avatar
Reviews: 18
Without thinking too much, I would imagine that you'd have to assign a cc function to each button in the FCB1010.
I would take a look at page 9 and 10 of the manual, as it tells you exactly how to program the switches. I tried to copy the text but for some reason it won't let me.
http://www.behringer.com/assets/FCB1010_P0089_M_EN.pdf
Jimmy
jb4674 is offline
post #14 of 17 (permalink) Old 11-10-2012, 08:28 AM Thread Starter
well i tried to use the FCB editor and i have the following problems ...
first i cant use the expression pedals ... they just dont send any midi output! i tried to calibrate them 2 times but still no luck!!!
here are the settings:
and im struggling with M Audio Uno ... most of the time the midi in LED doesnt work and no commands come through ... and sometime ... randomly it works perfect ... i installed the latest driver but i dont know what the problem is ...
RICHO is offline
post #15 of 17 (permalink) Old 11-12-2012, 03:32 PM
Reviews: 6
Which version of Pod Farm are you using? Pod Farm 2 has a midi learn feature that will simply use the midi being output without reprogramming the device.
behringer , foot switch , midi
Behringer FCB1010 Analog Switches NSR Gear, Equipment, Recording & Off Topic 1 08-17-2010 06:29 AM
WTB: Behringer FCB1010 (UK) pawel Classified Ads: Guitars and Gear 4 11-30-2007 05:25 PM
FS: PODxt + Behringer FCB1010 JoshIsNumber3 Classified Ads: Guitars and Gear 2 10-11-2006 05:42 PM
Pod XT & Behringer FCB1010 sam_at2001 Gear, Equipment, Recording & Off Topic 2 02-12-2005 01:19 AM
G-Major and Behringer FCB1010 - HELP! JiMoSiTY Gear, Equipment, Recording & Off Topic 5 08-08-2003 05:58 AM
