rack gear? - Jemsite
post #1 of 6 (permalink) Old 06-19-2006, 04:57 AM Thread Starter
rack gear?
hey
Been hunting around for some new gear, and was interested in getting some rack shiz, mainly the BEHRINGER feedback destroyer for my JSX (the amount of gain I like to use and my guitar pickups hum a bit). Wondering what exactly do I need to run one.
Also want to know if its any better than a stompbox that would filter the hum.
Maybe some other general rack info
cheers
wallie! is offline
post #2 of 6 (permalink) Old 06-19-2006, 09:08 AM
Re: rack gear?
Make sure you can return it! Not that it's a bad idea or unit, but there are potential problems:
1) These things lock in on feedback frequencies as they start to occur. With mics, there are a couple frequencies that stand out, depending on mic & monitor combination that's feeding back. Guitars have a BUNCH of different frequencies, depending on what you're playing (unless a microphonic pickup is the problem). You'll be locking down a lot of frequencies over a set.
2) Because it uses narrow band filters, you'll change your sound. For this reason, only use it in the monitor loop. If your feedback is coming from your amp or your mains, this won't help and you'll have to put this unit in the FOH (main) signal chain. Not good, sound-wise.
3) By cutting hum this way, you'll cut 60 Hz on your guitar, and probably some harmonics (120, 180, 240, etc). This will suck out your bass (especially if you use a 7 string or detune to B)
So, I would try to fix your problems at the source. For hum, look over your amp and pickups to determine if there's another fix you can live with. I can almost guarantee the result will be better than filtering after the fact. For feedback, figure out the main causes and fix it there. Feedback destroyers are band aids.
JESTER700 is offline
post #3 of 6 (permalink) Old 06-19-2006, 12:46 PM
Re: rack gear?
Yeah, don't use a feedback eliminator.
Use a Rocktron HUSH or a Boss NS-2..
Lefty Robb is offline
post #4 of 6 (permalink) Old 06-19-2006, 02:13 PM
Re: rack gear?
ISP decimator pedal or prorack G. Its a noise assassin.
Rudy is offline
post #5 of 6 (permalink) Old 06-19-2006, 02:49 PM
Re: rack gear?
the prorackG is waaaay to expensive @ $400+, when a NS-2 or HUSH would suit his needs just fine at under $100...
post #6 of 6 (permalink) Old 06-19-2006, 09:00 PM
Re: rack gear?
i am really happy with my mxr noise gate
guitardevil2005 is offline
isp decimator , rocktron hush
new amp and rack gear sirbrandon101 Gear, Equipment, Recording & Off Topic 4 04-30-2006 11:12 PM
FS: Some Rack Gear in the UK the.godfather Classified Ads: Guitars and Gear 4 02-15-2005 03:14 PM
Can some genius help me? Question on connecting rack gear corganrocks Gear, Equipment, Recording & Off Topic 1 11-02-2004 06:14 PM
Dumb question - how does rack gear work? jem7vwh Gear, Equipment, Recording & Off Topic 28 08-12-2001 12:18 PM
