Randall RH150 G3 effects loop - Jemsite
post #1 of 3 (permalink) Old 02-28-2017, 04:03 PM Thread Starter
Hey!
My bandmate has a Randall RH150 G3 head, and it seems we're having some trouble with the effects loop. We've put a tc electronic mojo mojo in the effects loop for solo boosting and it introduces a whistling noise. Also when we've put my isp decimator g string in the effects loop it had and extra whistleing noise when the decimator was turned off. I have an extra little hum with my valveking when the g string is introduced and the isp guys wrote it has something to do with the effects loop. Any suggestions?
ChaserHUN is offline
post #2 of 3 (permalink) Old 02-28-2017, 11:39 PM
Re: Randall RH150 G3 effects loop
almost sounds like a grounding issue. did you double check to make sure you are using instrument cables in the FX loop, and not speaker cables ?
It is also possible the FX loop jack has lost it's ground, or has a cold solder joint.
Have you tried non distortion/boosting pedals like a chorus or something like that ?
does it have send/receive level controls?
I saw a similar post over on sevenstring.org . They got a whistle just plugging straight in to the amp though. Could be a similar issue.
j.arledge is offline
post #3 of 3 (permalink) Old 03-01-2017, 12:46 AM Thread Starter
We've tried another overdrive pedal in the loop for solo boosting and it dod not have this problem, I don't get it why does it have it with the mojo mojo and the decimator. The amp does have level controls for the FX loop, and yes we did use instrument cables.
randall
Effects pedal for effects loop only dark_void86 Gear, Equipment, Recording & Off Topic 2 09-19-2015 03:45 PM
Choosing an EQ for the effects loop Neon_Knight_ Gear, Equipment, Recording & Off Topic 5 12-02-2012 07:01 PM
Effects loop? linuxpenguin Gear, Equipment, Recording & Off Topic 12 09-10-2011 10:23 PM
Effects Loop Help? Jafo Gear, Equipment, Recording & Off Topic 5 05-14-2006 09:10 AM
Problems using an effects loop-please help mginty Gear, Equipment, Recording & Off Topic 3 12-06-2001 03:46 PM
