recommend me multi fx for live use - Jemsite
post #1 of 7 (permalink) Old 06-21-2007, 11:36 AM Thread Starter
hey guys. I've been thinking about buying either the Zoom G9, Line 6 PodXT Live or the Boss GT-8 so that I can use that to plug into a P.A for band practices and gigs. I have a really cool half stack already (Engl powerball + Laney VH100R and marshall 4 x 12) but it's hassle for me right now to get it all about as I don't have a driving licence. So buying one of these would be easier for me to get about for the time being.
I would need some amp simulation that will give me a good quality tone that will cut through the mix live and also be easy to use. Some cool FX would be great too.
Which of the units that I've named would you recommend for using live? is there anything else I should look into?
My budget is up to 280 as I'm unemployed at the moment and would have to sell one of my guitars to buy it.
thanks very much
maliciousteve is offline
post #2 of 7 (permalink) Old 06-21-2007, 11:54 AM
Re: recommend me multi fx for live use
why not GNX3000 and ToneLab LE are in your list?
xklusivly4u is offline
post #3 of 7 (permalink) Old 06-21-2007, 11:57 AM
jb4674's Avatar
Reviews: 18
I'd say go with the GT-8. Unfortunately, since your funds are limited, the better choice would've been the GT-Pro, as it can be plugged directly into the pa system via its XLR outputs.
Jimmy
jb4674 is offline
post #4 of 7 (permalink) Old 06-21-2007, 12:46 PM
GT-8
The amp sims arent the best out there, but they're still pretty good. And because of it's effects loop (4-cable method), it'll fit right in with your half-stack when you need it to.
Any multi-fx without the option of putting effects before or after your actual preamp is pretty useless IMO. That's what makes the GT8 stand head and shoulders above all the other budget multi-fx pedals.
voodoo_child is offline
post #5 of 7 (permalink) Old 06-21-2007, 01:08 PM
WHAT ABOUT the New Digitech GSP 1101... ?
And about the Fx Loop Option, i think a POD XT PRO would be better than a GT-PRO and also cheaper.
extremist777 is offline
post #6 of 7 (permalink) Old 06-21-2007, 01:47 PM
jb4674's Avatar
Reviews: 18
There's a reason why the GT-Pro is more expensive. The GT-Pro sounds better than the POD products IMO and, its ability to arrange effects any way you want makes it an incredible piece of hardware for the price. The POD stuff, while a good candidate, gives out a lifeless sound next to the GT-Pro.
Jimmy
jb4674 is offline
post #7 of 7 (permalink) Old 06-21-2007, 03:11 PM
imo, dont, most multi fx i have used have done a not as good version of a stand alone stompbox.
however, the vox tonelab se sounds pretty good, tho im not sure what price it is (or what, if anything, the tube does...)
but for 280 you could get a good variety of pretty good stompboxes, which would not leave you with a useless multi fx once you have some money, but leave you with the beginnings of a serious pedalboard
depending on what music you play, you could probably get on fine with a gain box (or two), wah (if you solo lots) and a delay
imo
x
toma is offline
engl powerball , pod pro , vox tonelab
What multi effect to use direct to mixer PA? DotNetTim Gear, Equipment, Recording & Off Topic 13 05-21-2005 12:48 AM
FS: Ibanez UVMC Universe Multi Color ATD vwall Classified Ads: Ibanez JEM/UV Guitars 0 02-13-2005 02:09 PM
best multi effects pedal? Drache713 Gear, Equipment, Recording & Off Topic 9 02-20-2004 03:46 AM
Help ! Is the JS 1000 really multi radius ?? MarcD Ibanez JEM, UV, JS & Other Signature Models 19 12-10-2003 06:40 PM
Multi radius JS neck question EXCrosslink Ibanez JEM, UV, JS & Other Signature Models 8 02-07-2003 01:48 AM
