Recording Gear Questions - Jemsite
post #1 of 5 (permalink) Old 06-12-2006, 12:20 AM Thread Starter
Ok guys, I plan to buy a Shure SM57 mic and a Mackie 1202-VLZ PRO Micro Mixer.
So here's the signal chain - SM57 Mic > Mixer > Computer (SB Audigy 2 ZS Line-In)
1. Would this setup sound all right for basic guitar work recording (no major studio quality level of sound needed), considering I place the mic properly in relation to my amp?
2. Also, what software would I need, and what are some good recommendations?
3. Oh yeah, will I need any kind of mic-preamp, or will the mixer act as a preamp?
Thanks,
Wade
Edit: Should I just spend money on a preamp like this Behringer (since I will be recording one track at a time anyways)? http://www.***************.com/produ...amp?sku=182491 (instert musicians friend into blank)
Then I could use the saved money towards better software.
waylay00 is offline
post #2 of 5 (permalink) Old 06-12-2006, 12:55 AM
Re: Recording Gear Questions
(Warning: Ramblings of a pure amateur ahead...)
The mixer has a mic preamp per mic input, presumably. That being said, the SM57 is known to give very different results, depending on the mic preamp. Some preamps it loves (I'm told), others... not so much (speaking as the owner of preamps it loves not so much -- them being Yamaha aw4416 preamps -- which are pretty transparent preamps with not a heck of a lot of gain.)
Try it and see. The SM57 has the reputation of being a kind of default guitar cab mic, though often a small diaphragm condenser (e.g. marshall 603s to name one cheap example) can give better results for the amateur (in my very limited amateur experience.) And in the absence of a good room/quiet environment -- consider low freq air conditioner noise, traffic, jets, etc. -- recording direct through a modeller can give adequate and often better results than you are able to get with mics. One mic ain't gonna get you stereo, for instance.
Got no idea about software. I'm one of them crazy people that tries to use linux.
Ferrous Lepidoptera is offline
post #3 of 5 (permalink) Old 06-12-2006, 01:20 AM
hey waylay00, I'm using the exact setup you described.
My mixer/mic preamp is a behringer UB802 (mixer + mic phantom power preamp). So my setup is as follows
Shure SM57 -> UB802 -> Audigy 2 ZS line-in 2 -> software
I use audacity 3.0, or Reason 3.0 rewired to Ableton Live depending on what I'm doing on the PC end.
I'm an amateur myself, so don't take my word for it, but I like what I hear from my recordings. For me it's the best way to accurately record the tone I hear from my amp. That's one of the biggest problems I had with the POD XT. What you hear from your cab, may not sound the same in the recording through USB. But it is a lot more convenient.
The only downside I see to recording with a mic is that you really need to crank up your amp, and lower your mic output to get a clean recording without 60hz noise. It may not work out too well if you have neighbors. :P
btangel is offline
post #4 of 5 (permalink) Old 06-12-2006, 01:34 AM
Good luck =) There's only two or three programs that are really worth using on Linux for recording, and they're insanely hard to configure.
I'd just go with Audition, Tracktion, or Cubase, as far as software goes. I also recommend a second mic, like a Sennheiser e609 Silver, for close recording, and the sm57 for recording the back of the cab or from a few feet out in front of the cab to get a warmer, airy sound (good for lead tones). I bought a Mackie Onyx 1620, so I can record 8 mic inputs (8 preamps, plus another 8 channels of inputs without the pre's) directly to the computer, all on seperate tracks. It's really nice.
thadood is offline
post #5 of 5 (permalink) Old 06-12-2006, 01:04 PM Thread Starter
What about Sonar Home Studio XL? How is it for software?
Oh yeah, what are the difference between the Mackie Onyx 1220 and the Mackie 1202-VLZ Pro?
waylay00 is offline
List your recording gear and your thoughts on your gear.. gemini8026 Gear, Equipment, Recording & Off Topic 39 03-14-2007 06:37 PM
First recording gear ll Mr Blonde ll Gear, Equipment, Recording & Off Topic 8 03-28-2006 08:52 PM
Pictures of everyone's recording studio or recording gear rikkbeatty Gear, Equipment, Recording & Off Topic 38 08-22-2005 03:17 AM
Recording gear - need opinions balducci Gear, Equipment, Recording & Off Topic 18 05-04-2001 05:13 PM
