Recording Issues!! - Jemsite
post #1 of 8 (permalink) Old 09-28-2012, 02:21 PM Thread Starter
Reviews: 4
Talking Recording Issues!!
Ok, I am trying to record my guitars this week and I am having trouble making them sound good. I have a Digitech GSP 1101, through a BBE, and an EQ, and into a Peavey 6505+ for the power section. We are using 2 Sure SM57 mics, into the Presonus Firestudio. We are putting the cab in a small alcove with the walls covered with studio foam. Could my problem be mic placement? Any other tips?
dccomputersa is offline
post #2 of 8 (permalink) Old 09-28-2012, 02:41 PM
Re: Recording Issues!!
Can you be more specific? like describe what sounds bad?
first comes to my mind is try only 1 mic to see if things get better.
mertay is offline
post #3 of 8 (permalink) Old 09-29-2012, 12:27 AM
jb4674's Avatar
Reviews: 18
You could be having phasing issues but, it's hard to assess without knowing more details. Perhaps post a clip of what is sounding bad? Where in relation to the speaker do you have the mic placed at?
Jimmy
jb4674 is offline
post #4 of 8 (permalink) Old 09-29-2012, 03:08 AM Thread Starter
Reviews: 4
Talking Re: Recording Issues!!
I think the main problem is that the other guitar player recorded his guitars using the mic's he uses for vocals. I am using 2 sure SM57's. I think the problem is that the vocal mics are far more sensitive then the 57's, so when I crank my amp to record, its either not loud enough once recorded or it clips out to much and sounds like crap.
post #5 of 8 (permalink) Old 09-29-2012, 04:59 AM
Reviews: 13
Based on the information provided there could be a multitude of problems. Based on your last post you may not have your levels quite right. Have you got a pad switch engaged somewhere? As mentioned phasing could also possibly be an issue.
Pics could also be useful here to better understand your setup.q
-Wolfram
Wolfram is offline
post #6 of 8 (permalink) Old 09-29-2012, 12:00 PM Thread Starter
Reviews: 4
I will be over there later today and I will try to get some pics.
post #7 of 8 (permalink) Old 09-29-2012, 02:40 PM
Careful if the vocal mic. is a condenser, it might be damaged if not used properly when recording guitar.
mertay is offline
post #8 of 8 (permalink) Old 09-30-2012, 12:59 PM Thread Starter
Reviews: 4
We ended up using the 57's and it came out good!
Recording Guitar to PC via LIGHTSNAkE Latency issues plus more help !!! IbanezFreak777 Gear, Equipment, Recording & Off Topic 5 02-25-2010 05:14 PM
Recording Question (recording newb) Whey Gear, Equipment, Recording & Off Topic 2 12-08-2005 03:57 PM
Pictures of everyone's recording studio or recording gear rikkbeatty Gear, Equipment, Recording & Off Topic 38 08-22-2005 03:17 AM
What is the preferred Recording Software for PC recording? zenabi.777 Gear, Equipment, Recording & Off Topic 8 11-30-2004 10:31 PM
Drum Recording - Tips For Basic Recording? Two hands31 Gear, Equipment, Recording & Off Topic 6 12-09-2003 08:19 AM
