RME Fireface 400 driver nightmares or suggest me an interface - Jemsite
post #1 of 5 (permalink) Old 10-19-2012, 03:00 AM Thread Starter
Hi guys,
It's been forever since I last posted, but here I go with a little problem. My father gave me his old RME Fireface 400 audio interface and it is fantastic... when it works. I got at least 5 BSODs every day ever since I started using it and I said - to hell with it. I then went and connected my ancient Terratec Phase 24, which is very limited - only 2in/2out and the headphone monitoring out is noisy. Anybody here use a Fireface on 64-bit Windows 7 systems? Maybe there's a trick to make it stable? Some combination of firmware and driver versions? I really like the connectivity and sound quality, but the latest drivers are just a mess. RME is quick to point fingers at shoddy FireWire controllers, but I have a Texas Instruments one so the controller is not a problem. Besides, my other interface is rock stable on it.
voyager is offline
post #2 of 5 (permalink) Old 10-19-2012, 05:32 PM
jb4674's Avatar
Reviews: 18
Re: RME Fireface 400 driver nightmares or suggest me an interface
What are your machine's specs? Have you updated the Fireface's firmware to the latest version?
This is taken from the RME forum (http://www.rme-audio.de/forum/viewtopic.php?id=7348) :
Installation of RME Audio Interfaces under Windows 7
The procedure and instructions found in the manual and here are all fully correct and stay valid, except for the start of the installation. In Windows 7 Microsoft removed the automatic start of the Driver Software Update dialog - thank you Microsoft!
Therefore this dialog has to be started manually after the failed driver installation.
- Hit the Win key, type 'Device Manager', start the Device Manager by selecting it from the list and hit Return.
- The device is shown with a yellow warning symbol. Usually it is already found in the correct category, Sound, Video and Game Controller (Plug & Play detects a multimedia device). The Fireface UC is even shown with its correct name.
- Right click on the device and select 'Update Driver Software' from the context menu.
- The dialog 'Update Driver Software' appears. Now follow the instructions given in the manual.
And here's the link for the latest drivers:
http://www.rme-audio.de/en_downloads...river_fireface
Make sure to uninstall all drivers/RME software in your machine and then reboot prior to reinstalling to make sure everything is erased.
Jimmy
jb4674 is offline
post #3 of 5 (permalink) Old 10-20-2012, 03:28 AM Thread Starter
Did everything, even reflashed the firmware although it was already the latest version, rebooted after every step and so far so good. I'm gonna test it for a few days and if it still gives me BSODs it's going to the classifieds.
voyager is offline
post #4 of 5 (permalink) Old 10-30-2012, 04:05 AM Thread Starter
Looks like I solved my problems for good. The trick was to uninstall the drivers, disconnect the interface, reboot, replace the TI firewire driver with a one named "legacy", reboot and then install the interface as usual. No more, BSODs, no more dropouts, no more crackles under heavy load.
voyager is offline
post #5 of 5 (permalink) Old 10-30-2012, 12:02 PM
jb4674's Avatar
Reviews: 18
Glad you were able to sort out the problems that way. I had to do something similar with my Firestudio a few years ago when I built a new Win7 box.
Jimmy
jb4674 is offline
bsod , rme fireface
New oversampling ASIO driver Scali Gear, Equipment, Recording & Off Topic 23 05-22-2016 08:55 AM
WTB : RME FIREFACE 800 OR 400 lelahel Classified Ads: Guitars and Gear 2 10-05-2011 12:49 PM
nightmares having guitar built!!!! alxman Off-topic / Miscellaneous 15 08-12-2009 03:57 PM
Erotic Nightmares - Steve Vai cover Ad_Astra Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 8 08-22-2008 11:52 PM
MY NEW TAYLOR MADE DRIVER! Out Of This Swirled Off-topic / Miscellaneous 13 08-29-2007 08:12 AM
