Run Pod x3 through a speaker cab? - Jemsite
post #1 of 6 (permalink) Old 10-06-2010, 07:53 AM Thread Starter
Hi, i was just wondering if there's a way to run a pod x3 through a speaker cab? I've tried running it through my peavey bandit but i'm not satisfied with the sound it producing, i just want the raw sound of the pod. I am currently running it through my computer speakers and i love the raw sound of the pod. So if there a way to do it? thanks.
mystro is offline
post #2 of 6 (permalink) Old 10-06-2010, 08:17 AM
Reviews: 6
Re: Run Pod x3 through a speaker cab?
You'd likely need to use the Pod as a preamp, running through a power amp. Or, if your amp has an effects loop, you might be able to run it through that.
Philboski is offline
post #3 of 6 (permalink) Old 10-07-2010, 11:12 AM
You may wanna get an powered cabinet, such as atomic reactor cabs. They tend not to color your preamp's sound (POD in this case). They're quite pricey though (about $800).
The other way is, as Philboski suggested, to run it through a power amp or the effect's loop.
Another suggestion is to try and tweak the EQ, no matter which way you try to connect it. There was a thread in this forum with advice on the subject.
Aris_T is offline
post #4 of 6 (permalink) Old 10-07-2010, 01:41 PM
Tech21 makes a power engine 60 which can be found used for great prices.
Assumer is offline
post #5 of 6 (permalink) Old 10-07-2010, 03:59 PM
Reviews: 59
It's probably worth mentioning that just running it into the effects loop of a guitar amp is going to color your sound. Ideally, you'd want to run it into FRFR speakers at the end of the chain.
smooth55 is offline
post #6 of 6 (permalink) Old 10-08-2010, 05:52 PM
The thread I was talking about before popped up again!
http://www.jemsite.com/forums/f30/th...ne-103463.html
Hope this helps
Aris_T is offline
PA speaker help Devo Gear, Equipment, Recording & Off Topic 1 05-26-2010 03:14 AM
The 1 Dollar Speaker LethalAe86TypeR Off-topic / Miscellaneous 11 11-20-2007 06:57 PM
Need to change an amp speaker Cataclysm Gear, Equipment, Recording & Off Topic 4 11-02-2007 02:44 AM
Speaker Changes adamcbest Gear, Equipment, Recording & Off Topic 3 09-07-2006 05:46 PM
AMP/Speaker help. Timanator Tech: Setup, Repairs and Mods 3 05-16-2003 05:29 PM
