Running a TS9 from a 12vdc power supply - Jemsite
post #1 of 4 (permalink) Old 08-07-2012, 10:56 AM Thread Starter
Hi guys, I'm wondering if anyone has/does run an Ibanez TS9 on 12vdc? If so can you please comment on the overall effect producced by running it on 12vdc instead of the indicated 9vdc?
Thanks,
Nelson
nsabino is offline
post #2 of 4 (permalink) Old 08-07-2012, 11:56 AM
Reviews: 15
Re: Running a TS9 from a 12vdc power supply
I have done it with no issues. Unfortunately the pedal makes my rig a little noisy regardless of power source. Right now it's powered off a 1-Spot.
silverctr is offline
post #3 of 4 (permalink) Old 08-07-2012, 12:08 PM
Reviews: 98
I have.
It hits the opamp a little harder and doesn't produce much diffetence--just a little. Doesn't make it any grittier if that's what you're looking for.
AlaskaBat is offline
post #4 of 4 (permalink) Old 08-07-2012, 02:09 PM Thread Starter
Originally Posted by AlaskaBat View Post
I have.
Hi, thanks. That what I was aiming for a little more grit. Any mod recommendations you can give me?
Thanks,
Nelson
nsabino is offline
Whammy IV with box and power supply Sevenstringer Classified Ads: Guitars and Gear 1 07-21-2011 01:41 AM
WTB: Boss PSA-120(Boss normal power supply), or any supply that will work GuitarEvan07 Classified Ads: Guitars and Gear 1 06-03-2009 11:33 PM
BOSS PS-2/CE-3/TU-2/OC-2/T.C. Electronic power supply/MORLEY Power Wah BOOST Sevenstringer Classified Ads: Guitars and Gear 12 05-09-2008 04:05 PM
power supply... chopvai Gear, Equipment, Recording & Off Topic 3 02-24-2008 09:02 PM
What are you using for power supply? - The guys that use a l carlos seo Gear, Equipment, Recording & Off Topic 9 04-20-2001 06:29 AM
