sansamp psa1 and midi HELP! - Jemsite
post #1 of 2 (permalink) Old 04-20-2003, 04:48 PM Thread Starter
Hi:
I am going to buy a sansamp psa-1 with a tech 21 midi mouse controller.
I would like to know if when you change settings via midi, does it happen that small swap (i donīt know if this is the word to describe this) in the sound. I mean, that small silence that happens when you change a setting on a digital unit.
This happened me with the pod 2.0 and fb4 and made it useless live. I asdked line 6 and they said that to avoid this issue i had to use the same type of amp in all the settings. Ok, great, but for what do i need a pod if i only can use only one amp with more or less gain?
So, i am changing to sansamp, but i want to be sure that this wonīt happen
any help?
thanxs
theblackpage is offline
post #2 of 2 (permalink) Old 04-22-2003, 01:45 AM
No problem there, you can switch without the sound cutting out. Enjoy the SansAmp, I believe it's the best unit available!
babahi is offline
sansamp psa
Marshall JMP-1 vs T21 PSA1 Sansamp? pera_a777 Gear, Equipment, Recording & Off Topic 6 01-07-2008 02:11 PM
MIDI Amp switcher for non-MIDI amps - Yes, Rivera too. :) jeffrey Gear, Equipment, Recording & Off Topic 1 03-28-2002 03:34 PM
voodu valve & midi mate! - preamps and midi controller peel Gear, Equipment, Recording & Off Topic 4 07-11-2001 09:34 PM
Sansamp pSA1 strat110 Gear, Equipment, Recording & Off Topic 10 02-16-2001 07:25 PM
