A simple question about JCM800 footswitch - Jemsite
post #1 of 7 (permalink) Old 12-29-2008, 03:19 PM Thread Starter
I've had this head forever. JCM800 2210. Dual channel. Comes with a simple footpedal that switches channels and turns reverb on off.
Lately, it doesn't make the switch from channels very well, and will sometimes switch back for no reason.
The cable to the footswitch seems like a very cheap instrument cable, and is my first suspect.
So my question(s).
What type of cable is this? I've got some extra instrument cable to test with, but didn't want to hose anything just testing.
Also, There are sturdier footswitches available new from MF. Marshall P802 Dual Footswitch listed is for JCM 900 series. Same button configuration. Anyone ever use one of these on a JCM 800?
GLG421 is offline
post #2 of 7 (permalink) Old 12-29-2008, 06:23 PM
ScottB's Avatar
Re: A simple question about JCM800 footswitch
pics?
ScottB is offline
post #3 of 7 (permalink) Old 12-29-2008, 07:40 PM
Is it just a 1/4" jack on the cable? It could be the footswitch itself. Any 2 button footswitch with 1/4" jack should work. I used to have a Leem FS202 with my Classic 30, they're very strong footswitches.
littlephil is offline
post #4 of 7 (permalink) Old 12-29-2008, 08:37 PM Thread Starter
here's a pic...
top middle. Just a cheap 1/4 inch cable. two internal wires. not insulated very well. really looks like a piss poor instrument cable.
So the JCM900 switch is a 1/4 inch jack 2 button switch as well. Any 2 button should work?
GLG421 is offline
post #5 of 7 (permalink) Old 12-30-2008, 01:31 PM
The two button JCM900 footswitch has a stereo jack.
In order to switch both channels and reverb yours must also have a stereo jack and stereo cable (three wires) A two wire instrument cable will not work.
BTW Quality is relatively uninportant as it doesn't carry sound, only a switching signal.
eviltwin is offline
post #6 of 7 (permalink) Old 12-30-2008, 02:03 PM Thread Starter
Thanks, I'll crack the cable again tonight to make sure I saw what I thought I saw, which was two wires, but it would not work at all if it was not a stereo jack.
GLG421 is offline
post #7 of 7 (permalink) Old 12-30-2008, 08:28 PM Thread Starter
Yep, two wires + Ground wire.
Thanks, eviltwin
Geoff
GLG421 is offline
2210 , jcm 800 , marshall footswitch
A very simple question sers Pickups & wiring 4 03-09-2008 07:18 PM
crazy question about mesa footswitch??? adamcbest Gear, Equipment, Recording & Off Topic 11 07-13-2005 03:24 PM
Simple question, simple answer? jsdetrait Tech: Setup, Repairs and Mods 10 01-13-2003 01:32 PM
A really simple question Jeff Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 8 07-31-2002 06:14 PM
JCM800 Tube Change - Great n' EZ Mod for you JCM800 owners! goldboy Gear, Equipment, Recording & Off Topic 0 03-29-2002 01:36 PM
