SM57 recording info - Jemsite
post #1 of 6 (permalink) Old 10-23-2010, 10:55 AM Thread Starter
Reviews: 4
SM57 recording info
Hi guyze,
I'm currently shopping for a SM57 but I dont really know how recording actually works.
Is it interesting to buy the combo with the X2u USB thing? Instead of a convert cable to use on my PC microphone input? The SM57 doesnt come with the cable 80% of the time...
Thanks for the answers.
Phenixer is offline
post #2 of 6 (permalink) Old 10-23-2010, 09:39 PM
Re: SM57 recording info
that's one of the cheapest and most limited ways to do it. I don't know how the latency goes on the USB adapters. But usually people buy an interface. I've got a 'Presonus Firestudio Project', and that connects to my computer through firewire. And i can then plug up to 8 mics into that with about 3 or 4ms latency.
So what i'm saying is check out the interfaces you can buy. Depending on your needs, u can go from 2 inputs (solo guitar recording + a mate) and usually up to 8 (for drum kits).
Have fun researching this, i spent about 4-6 months reading up on different interfaces until i found the right one for the right price.
Toodles!
julzius is offline
post #3 of 6 (permalink) Old 10-24-2010, 09:19 AM Thread Starter
Reviews: 4
Thanks for the reply.
I only want to record myself (1 microphone, 1 Guitar cab, 1 computer).
And I didn't know if buying an adaptator from XLR to Computer gets the same sound quality and is cheaper than buying the microphone with the USB X2u.
The latency isn't really important here, I hear my playing on the amp and don't need feedback/other ppl playing.
Phenixer is offline
post #4 of 6 (permalink) Old 10-25-2010, 01:23 AM
by XLR you mean XLR to 3.5mm, then that depends on how good ur motherboard/sound card is. I got a fairly good latency time with my motherboard (Gigabyte EX58-UD3R), which was about 6-8ms.
But this method is USUALLY very poor, most motherboards can't keep up and put out latencys of about 30-300ms latency. But using a different ASIO driver helps (ASIO4ALL is very good).
But after latency, the sound quality isn't all that bad, for a while i had the headphone jack of my Line 6 POD going straight into my motherboard and tweaking the settings on the POD did the trick nicely.
Now after saying ALL of that, i havn't come across any XLR-3.5mm jacks.
The USBx2u sounds like a very good idea, and it's made for microphones and shure is a very well trusted company. I Havn't tried it, but i wouldn't think they would put out an adapter that was unusable. So the chances are, the X2U will sound clear and have a low latency through ur USB posts. Surely there's people on youtube who have done recordings with it.
The next step up for latency and sound quality is firewire, but that's when **** starts getting expensive.
A good recording tool i've seen (and i've used my friends one) is the Line6 Toneport UX2 (or summin like that). That's made for guitar and you can plug in a mic, or plug ur guitar straight in and use thier modelling software. It sounds good and is really cheap (cause it's a USB interface)
Hope something from this monster post helps you out on your way.
Toodles!
julzius is offline
post #5 of 6 (permalink) Old 10-25-2010, 02:01 PM
Reviews: 59
Unless you have a decent sound card, as has been said, I wouldn't recommend plugging directly into your computer. There are plenty of cheap interfaces and you'll want a pre-amp because the 57 needs a fair amount of gain unless your source is really loud.
As has been said,if you're just trying to record yourself, with a max of 2 channels at a time, then USB will be fine and you really don't need to step up to firewire. If you think, down the road, that you might want to record more than two channels at once, then you might want to consider firewire and save yourself from buying twice.
The Line 6 products are fine, I also recommend stuff like the Lexicon Omega for USB as I've got friends who use it and get good results. I myself use a Presonus Firestudio 26x26 and it's fantastic but way more than is necessary for demos by yourself.
smooth55 is offline
post #6 of 6 (permalink) Old 10-25-2010, 02:48 PM
Even IF you have a decent sound card, I wouldn't recommend it.
The first time I bought a dedicated recording interface, I bought a new computer at the same time. I got the computer in a week or so early, the interface order got delayed, so for that first week I installed my recording program and experimented plugging straight into the (good prosumer grade) soundcard. I was initially kind of underwhelmed - it was a brand new computer, but it didn't sound THAT much better than my old laptop I'd been using for 6-8 years before that.
Then, I got my M-Audio interface in the mail. Hooked it up, and immediately had the single-biggest jump in recording quality I've ever seen.
There are a bunch of cheap one- or two-channel USB or Firewire interfaces on the market - if your budget permits, I'd really recommend grabbing one.
Drew is offline
sm57 microphone recording
FS: Shure SM57 satchmo72 Classified Ads: Guitars and Gear 1 05-29-2010 12:37 AM
FS: Fake Shure SM57 GuitarEvan07 Classified Ads: Guitars and Gear 3 03-21-2010 05:10 AM
WTB: Shure SM57 GuitarEvan07 Classified Ads: Guitars and Gear 0 11-05-2009 09:46 PM
FS: SHure SM57 elcid Classified Ads: Guitars and Gear 1 06-20-2007 05:52 PM
I can only choose one: SM57 or SM58? Jeff Gear, Equipment, Recording & Off Topic 5 08-19-2004 09:05 AM
