Sonar 8.5 Issue, Recording playback is 1.5 times faster - Jemsite
post #1 of 2 (permalink) Old 01-07-2020, 10:16 AM Thread Starter
Hello everyone, I hope one of you can give me some insight into my problem here.
I just reinstalled Sonar 8.5 producer edition. I have never run into this issue before.
When I record a track it is sped up when I play it back. It doesn't gradually get faster, it is around 1.5 times faster from the beginning to the end.
I know it's not my sound card, which is an Maudio Delta 1010LT because I can record in Audacity and everything works fine.
I have installed Sonar 8.5 several times and never ran into this issue.
Any Ideas? Any input would be helpful, Thank You.
TongueNGroove is offline
post #2 of 2 (permalink) Old 01-08-2020, 12:23 AM
Interesting...I’ll take a stab at it:
Weird things like this can happen if the sample rate within the DAW session is different than the sample rate of your audio interface. I would start by making sure the sample rate Sonar is using to record audio matches the sample rate your audio interface is using.
Formerly Given To Fly is offline
sonar 8.5 recording
