Sonic foundry Acid pro Key not changing - Jemsite
post #1 of 1 (permalink) Old 01-12-2009, 04:55 AM Thread Starter
Hi,
I'm using Sonic foundry acid pro3, when i load a guitar loop and mark the spots where i want the key to change[insert key change] it marks the spots with the key change, but when the cursor passes it, it doesn't change the key even though the key indicator changes to the key i changed to. is there anything else i need to do in addition to marking the key change spot? why isn't the key changing? any help would be greatly appreciated.
Thanks in advance
soullavee is offline
acid , foundry , pro , sonic
Acid Pro 2.0 Question vwall Gear, Equipment, Recording & Off Topic 2 07-08-2004 03:39 AM
Acid Pro Problems Mytonezucks Gear, Equipment, Recording & Off Topic 5 05-14-2004 04:52 AM
Acid Pro Jeff Gear, Equipment, Recording & Off Topic 7 12-11-2002 09:03 PM
orchestral loops from Sonic Foundry has anyone used these? Superuser Gear, Equipment, Recording & Off Topic 9 09-11-2002 07:36 AM
