Speaker Replacement - 8 or 16 ohm - Jemsite
post #1 of 2 (permalink) Old 11-13-2005, 10:39 PM Thread Starter
Is one better than the other? The stock speaker is 8 ohm. Does that automatically mean I should use an 8 for the replacement? I realize that going to 16 will cut the power in half (V=IxR), but are there other considerations?
By the way, I'm talking about a Vox AD50VT amp. Any recommendations for a speaker? I'm considering a Celestion Vintage 30.
ric232 is offline
post #2 of 2 (permalink) Old 11-13-2005, 11:11 PM
Re: Speaker Replacement - 8 or 16 ohm
if the amp has an 8 ohm speaker, replace it with an 8 ohm speaker. Putting a 16 ohm in it will mess up the amp in the long run.
i think a vintage 30 would be good, or a hellatone 60.
go to www.avatarspeakers.com and check the description on the hellatone. also avatar speakers has the best price on celestion speakers around.
j.arledge is offline
celestion vintage , ohm speaker
Speaker Replacement Recommendations Peavey Bandit Libertyordeath Gear, Equipment, Recording & Off Topic 20 10-13-2011 11:28 AM
Run Pod x3 through a speaker cab? mystro Gear, Equipment, Recording & Off Topic 5 10-08-2010 05:52 PM
PA speaker help Devo Gear, Equipment, Recording & Off Topic 1 05-26-2010 03:14 AM
Speaker Changes adamcbest Gear, Equipment, Recording & Off Topic 3 09-07-2006 05:46 PM
AMP/Speaker help. Timanator Tech: Setup, Repairs and Mods 3 05-16-2003 05:29 PM
