SS Clean Tone for Multifx? - Jemsite
post #1 of 9 (permalink) Old 02-18-2009, 12:50 AM Thread Starter
Reviews: 23
Question SS Clean Tone for Multifx?
Hello eveyone. I have an MG100DFX combo, and I think the clean is fantastic. It's not tubelike, but it is enough for me (at least for now). A few weeks ago, I got a Digitech RP500 multi effects processor and tried to hook it up with the amp. I found it ok (haven't set it up much yet) and I feel that it has the potential to sound great when setup properly, but I am wondering if it would be the same for the rest of you guys. Knowing that there are a lot of "tone chasers" here in the jemsite forums, I would like to ask you guys if it would sound at least decent. Thanks in advance.
theapprentice is offline
post #2 of 9 (permalink) Old 02-18-2009, 05:10 AM
Re: SS Clean Tone for Multifx?
I had a marshall mg100 half stack about 9 years ago. I thought it was a good amp, not the best but it still sounded good. I also have an rp250 and did own an rp350 before they came out with the rp500. I like the sounds i get out of it but I don't really use it for much anymore except reverb. The distortions are decent in the rp250, I like to dial in the JCM modeled sound and put the gain around 50-60 and then boost it with a distortion box like a ts-9 or ts-808.
All in all, i think you could get a good sound out of that combination of gear. digitech multi-fx pedals are some of the best sounding multi-fx out there IMO.
Foulacy is offline
post #3 of 9 (permalink) Old 02-18-2009, 10:34 PM Thread Starter
Reviews: 23
Ok, thank you. How about the effects loop? Should I use it or should I run the RP in front of the amp?
post #4 of 9 (permalink) Old 02-18-2009, 10:40 PM
mi2tom's Avatar
You should try it out then. Compare em both which you like through the effects loop are up front. Personally I never like multi effect through effects loop, more time consuming to get the sound you want, you need to tweak and tweak and tweak. I normally go through earphone to my multifx and dial in to what I want and then plug it into the input and tweak those bass mid and treble knob to get what I want, much more easier, plus the plugging into the input jack you'll have more punch and better presence, but be sure to turn off those cabinet modelling in your fx or else it'll alter your sound completely.
mi2tom is offline
post #5 of 9 (permalink) Old 02-18-2009, 11:01 PM
going through the back of the amp bypasses the preamp...
shogun is offline
post #6 of 9 (permalink) Old 02-18-2009, 11:31 PM
mi2tom's Avatar
Yeap I know that, what I'm saying is many people thought by using the multifx preamp modelling they get the real thing but no... It's still an effect so use it like an effect not treating a multifx as a bunch of expensive amp in a small box
mi2tom is offline
post #7 of 9 (permalink) Old 02-19-2009, 01:49 AM Thread Starter
Reviews: 23
I am actually going to do amp modelling with it. I don't really expect convincing sounds from the RP500, but at the very least usable ones. So what should I use then? The input or the fx loop?
post #8 of 9 (permalink) Old 02-19-2009, 02:20 AM
ok if you put it in the effects loop, don't turn on any of the amp modeling, cabinet modeling, distortion or anything like that. if you are using it for distortion and modeling you HAVE to put it out front.
Foulacy is offline
post #9 of 9 (permalink) Old 02-19-2009, 02:36 AM Thread Starter
Reviews: 23
Ok, thanks for the time everyone.=)
clean channel , marshall mg , rp500
Testament's Clean Tone bonehead189 Gear, Equipment, Recording & Off Topic 10 02-19-2009 05:39 PM
Clean tone in JEM? xklusivly4u Ibanez JEM, UV, JS & Other Signature Models 25 09-11-2008 06:16 PM
Clean Tone Jeff Gear, Equipment, Recording & Off Topic 7 01-15-2004 03:52 AM
Best small clean practice amp - Solid state, good clean tone Kremlin Gear, Equipment, Recording & Off Topic 9 04-09-2002 11:03 PM
POD...clean tone? - How to.. cowcowcow Gear, Equipment, Recording & Off Topic 4 12-28-2000 12:21 PM
