Staaaaaaatic. Not Static X, They're Horrible.. - Jemsite
post #1 of 13 (permalink) Old 07-15-2011, 01:35 PM Thread Starter
Hey guys,
Issues with the amp. I use Alot of gain, and even when the volume is down on the guitar it has a constant, crrrrrrrrrrrrrarararrrrarararrrrrrr coming from the speakers. A guy I know seems to think it it was a problem with the ground. So he said before you go buy a pedal, try filing down the larger prong on a 3 from adapter and flip the cord upside down to reverse the polarity. Well that didn't work. so would a simple noise gate, or suppressor help? If so, are there any cheap(ish) that work well?
Thanks, Jake.
eyebahnez is offline
post #2 of 13 (permalink) Old 07-15-2011, 01:49 PM
Reviews: 59
Re: Staaaaaaatic. Not Static X, They're Horrible..
I think to better help with the diagnosis, we need a bit more information. The most common cause, as you said is inadequate grounding as well as RF interference. If you're using a tube, it could also be tube related noise/microphonics.
Is the static perceptible when playing at volume?
Are you still getting a guitar signal through?
Is this static a recent development?
Does it occur regardless of where you plug it in at your house?
Does it happen with the guitar completely unplugged from the amp?
Are you getting it with just a guitar plugged in, with guitar + effects, etc.?
Answer those and it'll be a easier to accurately diagnose the problem.
smooth55 is offline
post #3 of 13 (permalink) Old 07-15-2011, 01:58 PM
Removing the ground is a very stupid idea.
musikron is offline
post #4 of 13 (permalink) Old 07-15-2011, 02:21 PM Thread Starter
1. It's not there while i play.
2. Yes guitar signal is fine.
3. No, it's always been there.
4. I've only tried in two room, My room and basement. It's a Halfstack, sooo.. not moving it around is the best idea..
5. No, When there is nothing plugged into the input, it's silent.
6. It's guitar to amp, no effects.
post #5 of 13 (permalink) Old 07-15-2011, 03:47 PM
Have you ever tried another guitar into that amp?
I'm saying this because guitars have ground too, and when you lose the ground inside the guitar you get unwanted noise and static from your amp.
I have had this problem many times (after change pickups) and when a didn't have the proper care.
Make sure is not the guitar.
Vintage_freak_forever is offline
post #6 of 13 (permalink) Old 07-15-2011, 04:05 PM Thread Starter
It does it with all guitars. I just got new pickups in my main guitar, but the guy who did the wiring, said he grounded the crap out of it. Sooo.. I'm, lost.
post #7 of 13 (permalink) Old 07-15-2011, 04:42 PM
If you think the amp is the responsable you could check some things like:
1.- Sometimes, when you have the spring reverb too close to the transformers (or speakers) and you don't have the proper shield, you get unwanted noise. You could check if without the reverb spring do the same noise.
2.- Check tube by tube, with a wood pencil. Turn on the amp, and touch tube by tube with the pencil, that's the way to detect a bad tube (bad tubes tend to make noise when you touch them with a piece of wood).
3.- Try to plug your amp to another power source
4.- What kind of cables are you using with your guitar? Cheap cables can add unwanted noise from many sources like a TV, cellphones, etc...
post #8 of 13 (permalink) Old 07-15-2011, 05:07 PM
Reviews: 4
Are you using the same lead? is it any diiferent on the clean channel, or different settings?
fwd0120 is offline
post #9 of 13 (permalink) Old 07-15-2011, 09:58 PM
Reviews: 59
If you're not getting the static when there is no guitar plugged in, my guess is that it's something with the guitar/cable that's picking up the noise/interference and the amp is just amplifying it.
Does it have the static with the cable in without the guitar plugged into the other end? If it doesn't have the noise when a guitar is not plugged in and it does have the noise when any of your guitars are plugged in, it seems that the cable is the constant. As FW said, are you using the same lead cable?
If possible, I'd also try to restore your plug so that your amp doesn't fry with a power surge during the next thunderstorm.
smooth55 is offline
post #10 of 13 (permalink) Old 07-15-2011, 11:03 PM
Some amps break the circuit when nothing is plugged in, what kind of amp is this? ( I am surprised no one has asked yet.)
musikron is offline
post #11 of 13 (permalink) Old 07-17-2011, 10:42 PM
BINGO!!!
xSoDopeImHeroinx is offline
post #12 of 13 (permalink) Old 07-18-2011, 02:07 PM
elcid's Avatar
I hope its an IEC type cable with the C13/C14 ends on it so you can easily replace it immediately
elcid is offline
post #13 of 13 (permalink) Old 09-10-2011, 02:52 PM
Hey guys,
Thanks, Jake.
Is your guitar shielded?
Hating-pyramids is offline
amplifier , noise gate , noise suppressor , static
Volume/Tone=Static Hum? Guitarist-Jonny Tech: Setup, Repairs and Mods 5 03-06-2009 09:43 AM
Amp is making a lot of static/noise pradador Gear, Equipment, Recording & Off Topic 0 01-25-2008 11:34 PM
OMG - This is horrible:( JJEMMER777 Off-topic / Miscellaneous 27 01-06-2007 02:47 AM
Static Mott Power Tech: Setup, Repairs and Mods 0 08-18-2006 03:39 AM
Static Electricity in my car. Gex Off-topic / Miscellaneous 2 03-25-2006 11:22 AM
