straight vs angled cabinets (marshall 1960A vs B) - Jemsite
post #1 of 9 (permalink) Old 08-11-2012, 02:52 PM Thread Starter
In terms of beefyness, thud, bass feeling, is there a lot of difference between both cabs of a same brand?
Even at low volumes I like to feel this punch in there.
Thanks for your opinions
Silverburst is offline
post #2 of 9 (permalink) Old 08-11-2012, 04:44 PM
Reviews: 98
Re: straight vs angled cabinets (marshall 1960A vs B)
I always use angled cabs if run like a half stack.
That way, I get the top 2 speakers angled up at me.
I don't notice any more bottom end that way--just clarity.
AlaskaBat is offline
post #3 of 9 (permalink) Old 08-11-2012, 05:04 PM
Agree with Rob. If you're only running a half stack the angled cabs sound clearer due to the speakers being angled up at you. Actual tonal response between the same cabs straight & angled should be very similar though.
If you're looking for "punch" you're prob going to want to stick with sealed back cabs. The sealed back cabs tend to be tighter and punchier than the open back cabs.
kfssdude is offline
post #4 of 9 (permalink) Old 08-11-2012, 05:35 PM Thread Starter
Yeah it is supposed to be half stack. So you guys wouldn't think a straight cab would have a real noticable bottom end compared to its identical angled brother? 1960's are closed back so np there. Cloed backs indeed have more bottom end.
post #5 of 9 (permalink) Old 08-11-2012, 06:24 PM
i`ve owned both and the straight cab did seem to have a deeper sound to it,not sure why,could be the slight design changes or just the fact the top 2 speakers are not pointing up.
paulh123 is offline
post #6 of 9 (permalink) Old 08-11-2012, 06:53 PM
I always use the B cab if only using a single cab,its a bigger cab so more meat in the tone.
The last Marshall stack i owned advised this also in the manual.
Loads of guitarists only use B cabs even when stacking myself included,in fact i only own B's now.
corey j grieve is offline
post #7 of 9 (permalink) Old 08-11-2012, 07:52 PM
Yeah in the Marshall 1960 series particularly, the B cabs do seem to be a little bassier/boomier but they are also heavier, slightly larger than the A's so it's not really te same comparison as, say, the Mesa Recto cabs. The Rectos are pretty comparable said from the angle/straight cab design and sure enough they sound virtually the same. Same deal with my 5150 cabs. So diff manufacturers may actually have differences between cabs that go beyond the angle/straight design. Just do a little homework & try to hit a GC & test run some cabs before you buy.
kfssdude is offline
post #8 of 9 (permalink) Old 08-12-2012, 02:31 AM
Even with Mesa's and Peavey,B cab has more air.
There's loads of info on-line on this subject,usually connected with studio's and sound engineer's.
I also caulk all my cabs for complete seal and also use baffling to settle boom frequencies.
post #9 of 9 (permalink) Old 08-13-2012, 05:09 AM Thread Starter
Thanks for the feedback guys! I'll probably go for a B. It will probably be a marshall since it will be a marshall head. I like m matching.
W T B - Marshall 1960A in NJ Sevenstringer Classified Ads: Guitars and Gear 1 08-01-2011 05:16 PM
WTB: Marshall 1960A cab GuitarEvan07 Classified Ads: Guitars and Gear 0 09-20-2009 02:50 AM
Marshall 1960AHW Handwired Angled 4x12 Ayrton Classified Ads: Guitars and Gear 0 09-09-2008 12:15 AM
marshall 4X12 cab 1960a swordofjoshua Classified Ads: Guitars and Gear 1 07-23-2005 10:00 AM
Cabinet for Halfstack - Angled or Straight Kipperfetish Gear, Equipment, Recording & Off Topic 4 03-21-2005 03:26 PM
