Strange static noises using sound font files - Jemsite
post #1 of 7 (permalink) Old 01-27-2003, 01:08 AM Thread Starter
I get strange static "tics" on the master track after I recorded. I found out that I comes from my sf2 files. Whenever I attach an sf2 file to my project (cakewalk 2xl) and I playback the composed track, there's some kind of static on the track ; some "spits" and "ticks" here and there. Could it be because I have only a 900mhz processor? (I have 768mgRam so I guess its not a mem problem...) Or could it be something else? Anyone who has whatever knowledge on sf2 files, I would be VERY happy to hear from. Thanks for your help.
-Mathieu
zulumika is offline
post #2 of 7 (permalink) Old 01-27-2003, 08:27 AM
How did you isolate the problem?
I would contact Cakewalk directly, they are VERY accessible and can answer your questions very quickly !
Bamm
bammbamm is offline
post #3 of 7 (permalink) Old 01-27-2003, 03:12 PM Thread Starter
I isolate the problem by mixing-down only the sf2 track (was a piano file downloaded from hammersound) and making a master track out of it. Then I listen to it and there was "ticks" and "spits". I cleaned it a bit but I can't get rid of them all. The master file is on "mp3.com" ; search for "Mathieu Bourgon", you should find me. (the approval takes about 2 week so my guess is by the second week of feb. you should see what I mean.
-Mathieu
zulumika is offline
post #4 of 7 (permalink) Old 01-27-2003, 08:43 PM
That sounds like a clocking issue. What is the sample rate and are you feeding any type of digital audio or have any digital devices conected to your system? If not make sure that your sync reference is set to internal (probably somewhere in preferences)
Need more details, feel free to MSN me.
30yroldpig is offline
post #5 of 7 (permalink) Old 01-29-2003, 11:05 AM
I had the same problem @ different times with my soundblaster card - soundfonts are a great idea, but DXi and/or VSTi is the way to go...
ardell henderson is offline
post #6 of 7 (permalink) Old 01-29-2003, 12:00 PM
I've never worked with soundfonts, but when you're getting crackling from a soft synth/sampler it is usually a latency problem. Try increasing the latency and I'd be surprised if that doesn't cure your problem.
Soup Kitchen Studios is offline
post #7 of 7 (permalink) Old 04-10-2003, 07:35 PM
Here's my assesment...
It's either the sound font or...
Ive been using sound fonts for a few years (since the live card came out)
Since youre using the PC that has the SF loaded on it to record also... you may have a problem with memory usage... Since the SF takes up physical RAM, you may be short changing yourself when it comes to the actual recording. If you have the means (just as a test) play the tracks to some kind of external recorder (even a tape deck) and see if you get the problem.
If you find the track is clean, get some more RAM.
I was using a P2 450 with 256M and had no problems
Im doubting its a clockinig issue since the card converts the SF to analog and then reconverts it to digital to make the wav out of it.
If you want some SF's lemme know, I have about a gig and a half, I'd be more than willing to share!
A_Paganini is offline
Strange noises from amplifier. TheMusicBucket Gear, Equipment, Recording & Off Topic 11 12-12-2009 12:59 PM
Amp start making constante static noises :( dime666bag Tech: Setup, Repairs and Mods 1 06-02-2008 10:11 AM
Strange noises in the neck when doing whammy dives graziomanu Tech: Setup, Repairs and Mods 16 09-04-2007 06:35 AM
Upload Sound Files??? BLAKK:JAKK Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 06-27-2006 10:13 PM
Strange static noise coming from my Telecaster Deluxe Superuser Tech: Setup, Repairs and Mods 3 12-18-2005 08:32 AM
