Straplocks for my JEM :-| -- what are you using? - Jemsite
post #1 of 24 (permalink) Old 02-21-2003, 10:10 AM Thread Starter
I bought Schaller straplocks for my JEM, but the screws are much smaller so they really aren't secure. The JEM's original screws for the buttons don't fit through the Schallers.
I curious what others are using or options I might be missing.
Thanks.
bpd111 is offline
post #2 of 24 (permalink) Old 02-21-2003, 10:26 AM
cerealk's Avatar
on one of my jems i use a strap (i will remember the name later) which fits around the Ibanez strap lock buttons
remind me later and I will look it up!
on the others I use Dimarzio screws and clip lock straps
e.g. http://www.jemfest.com/misc/simon/oz/end2.jpg
cheers
Simon
cerealk is offline
post #3 of 24 (permalink) Old 02-24-2003, 12:10 AM
Here's a tip that might help. Take a tooth pick or two and stick them into your original screw hole for the strap buttons. Break them off flush ( or cut them) and dab a little wood glue in there. You can then use your screws that came with your schaller locks and will have a nice tight fit. I'm a firm believer in shaller straplocks and have used this little trick to great success on all of my guitars. I hope this helps you out!
Ryan
rgto is offline
post #4 of 24 (permalink) Old 02-24-2003, 04:11 AM
cerealk's Avatar
it is a SURE-LOCK strap
cerealk is offline
post #5 of 24 (permalink) Old 02-24-2003, 11:37 AM
Ryan
Yep, that's what I did too ... only I didn't have wood glue at the time. I just stuffed the holes with as many toothpicks as I could so tight that nothing would come out (I very carefully used a jeweler's hammer to get the last ones in) then rescrewed the holes. That was about a year ago and I've had no problems since. I would however suggest the wood glue procedure just to be sure.
LJ
Patrick Deno is offline
post #6 of 24 (permalink) Old 02-25-2003, 12:07 PM
DiMarzio Clip Locks
mange is offline
post #7 of 24 (permalink) Old 06-24-2003, 03:06 AM
How well does the Sure Lock work?
passionwarfare is offline
post #8 of 24 (permalink) Old 06-24-2003, 03:19 AM
cerealk's Avatar
no problems with the strap for the last 10 years and it is still in active use
cerealk is offline
post #9 of 24 (permalink) Old 06-24-2003, 03:55 AM
Yeh - DiMarzio clip-locks all the way.....and they look pretty good too!
the.godfather is offline
post #10 of 24 (permalink) Old 06-24-2003, 06:34 AM
I love that seatbelt material. Its like silk compared to the normal straps Ive used that rub your exposed neck and make it sore and raw.
Just watch the clip when you put your guitar in the case. Never put the clips on the guitar. If you have a Jem or a similiar guitar you can fold the one on the cutaway out towards the storage compartment and the other one you have to fold so it sticks outside the case.
Ive used them for years. Ive always been carefull and despite warnings from other people Ive never scratched my guitar.
Dan D Mahnn is offline
post #11 of 24 (permalink) Old 06-24-2003, 07:15 AM
DiMarzio ClipLock.
nuno is offline
post #12 of 24 (permalink) Old 06-24-2003, 09:54 AM
I've got one of those Planet Waves locking straps (can't remember the exact name right now), and it's great, except for a few things I had to fix: The backs of the strap ends (the parts that clip onto the guitar) are rubber, with bumps, and they not only scuff up the finish on your guitar, they prevent natural movement of the guitar while playing. Easily fixed by putting a piece of cloth the size of the strap ends with a hole in the middle for the strap button between them and the guitar. Another problem is that it started to unscrew the strap buttons on my guitar, so I popped the strap buttons out and epoxied them back in. Apparently wood glue has a habit of corroding things like screws, so that's why I used something else.
And in my testing I discovered that when hit with a LOT of force, the ends pop open and almost fall apart (probably would have if I had pushed a little harder on my guitar), but it takes a LOT to do that. Still wouldn't mind a better design for the strap ends.
Two hands31 is offline
post #13 of 24 (permalink) Old 06-24-2003, 01:38 PM
Just like many others here stated, the Dimarzio Strap-lock is the answer. The best damn strap out there! btw - if the screw holes get stripped in the guitar, use a bit of wood glue in the hole and it takes care of it no problem.
Guitarlos2 is offline
post #14 of 24 (permalink) Old 06-24-2003, 03:59 PM
I have to agree with you on that.....
bob mclaughlin is offline
post #15 of 24 (permalink) Old 06-24-2003, 05:39 PM
any one try the cotton dimarzio clip lock straps (as opposed to the nylon)?
How do those feel?
davester1234 is offline
clip lock strap , clip lock straps , cliplock strap , cliplock straps , dimarzio clip lock , dimarzio clip lock strap , dimarzio clip lock straps , dimarzio cliplock , dimarzio cliplock strap , dimarzio cliplock straps , dimarzio strap , guitar shop , planet waves , strap button , strap buttons , strap lock , strap locks
Similar Searches
Straplocks that are direct fit for RG metalter Tech: Setup, Repairs and Mods 9 06-01-2012 02:11 PM
straplocks on a rg20th callen3615 All Other Guitars (including Prestige) 30 02-06-2009 05:08 PM
WTT/WTS: Dunlop straplocks FOR Schaller straplocks. Stygian Classified Ads: Guitars and Gear 5 07-29-2008 05:01 PM
Straplocks Js90Lx Tech: Setup, Repairs and Mods 2 02-12-2007 09:20 AM
what color for straplocks? stratman219 Ibanez JEM, UV, JS & Other Signature Models 17 05-17-2003 10:44 AM
