String bending and floating trems - Jemsite
post #1 of 14 (permalink) Old 02-22-2011, 09:05 AM Thread Starter
Hi folks. I am new to the world of floating trems and relitively new (18 months in!) at guitar playing in general.
Recently bought an RG with the cheapy edge III bridge.
I am finding when bending strings, particularly in the higher registry, that the trem tilts forward and puts the other strings out of tune. No matter what method I employ of damping the strings above and below the one being bent, once amped up you can still hear it!
I can cleanly bend strings on my GIO with the vintage trem and my hardtail Schecter, so I don't think it is technique issue.
Any other ideas? Or is this an inherent thing with floating trems? Which may account for why I don't see any blues players using them?
Please help to put my mind at rest.
And don't laught at my gear!! Gotta start somewhere right?
olydj2000 is offline
post #2 of 14 (permalink) Old 02-22-2011, 09:22 AM
Reviews: 64
Re: String bending and floating trems
Blues players don't use trems because......they're blues players,they're closed minds just like metal players who think a metal player should only plays metal lol
How many guitarists you see using trems?
Do you hear that problem with Vai,Satch,Malmsteen whoever?
Nope.
So obviously the problem is there.
I don't know how to fix it cause I never had that problem or any problem with trems.
Generally when I'm bending a note(s) while my left hand is bending it's mutting the others strings.It's automatic so I never payed attention to that.
And of course everytime you bend a note(s) trem will always move,it was made to do that
6fingers is offline
post #3 of 14 (permalink) Old 02-22-2011, 10:06 AM
IbanezFreak777's Avatar
Reviews: 25
The only reason you should see this as a problem is if you want to bend a string and then ring out an open string at the same time. Bending a string will pull the other strings out of tune untill you return the bend.
This is because all the strings are joined for lack of better words. A fixed bridge allows each string to bend indepentantly of the entire trem.
pros and cons on both sides of the trem argument..
As long as you dont want to bend a string and ring out another, you should be fine with a floating.
I find that after many years using the Edge trem, I just know what my limits are when bending 2 strings, I know exactly how far I can go before I create bad sounding notes.
IbanezFreak777 is offline
post #4 of 14 (permalink) Old 02-22-2011, 05:51 PM
Reviews: 120
Yep, inherent issue with floating trems. You cab install a Tremol-no so you can lock the bridge when not using the whammy bar. Ive got a couple installed, they are great.
LonePhantom is offline
post #5 of 14 (permalink) Old 02-22-2011, 06:50 PM
Reviews: 3
that happens with floating trems, and can even happen with the fender trems
IBZshredder is offline
post #6 of 14 (permalink) Old 02-23-2011, 08:43 AM
This cannot be avoided when trying to sound the note you're bending up and an open string simultaneously, but if you're bending up a note to sound in unison with a fretted note on the next string (a common blues/rock feature) you can address this by microbending the second fretted note to be in tune again.
Alternatively you could grab the trem and keep things in tune, but that's quite a bit harder, you're better off wobbling the trem around a bit.
eviltwin is offline
post #7 of 14 (permalink) Old 02-23-2011, 10:46 AM
Doesn't work
dragsternj is offline
post #8 of 14 (permalink) Old 02-23-2011, 01:17 PM
Reviews: 57
I block any of my floaters so that they only go down, and don't pull up. I've had a few nightmares at shows while using floating bridges, breaking a string mid-song.. things like that. With a blocked trem I can still usually pull off the song until the end and then switch.
Anyway, after blocking I generally tighten up my springs, pluck the low E, and bend up the B string 15th fret a whole step. If the E string drops pitch, I tighten again.. repeat until I can bend the B string a while step with E string still ringing in tune.
blackspy is offline
post #9 of 14 (permalink) Old 02-23-2011, 03:47 PM
Blocking it would defeat the purpose of a floating trem.
eviltwin is offline
post #10 of 14 (permalink) Old 02-23-2011, 04:18 PM
Reviews: 4
Another fix is a stabilizer.It won't take away the ability to pull like a blocker.Here's a good article on tremolo stabilizers http://joe.emenaker.com/TremStabilizers/
guitarnub3 is offline
post #11 of 14 (permalink) Old 02-23-2011, 04:50 PM
Reviews: 57
Yup...
blackspy is offline
post #12 of 14 (permalink) Old 02-26-2011, 12:41 PM
Wow that sounds like a great fix to most of MY floating trem problems.
Thanks for the tip!
Deep2 is offline
post #13 of 14 (permalink) Old 02-26-2011, 10:09 PM Thread Starter
Yes the Tremol-no look very promising.
Another cheaper alternative, or temporary one, that I was told of at my local shop was to try wrapping a scrunchy around/over the strings of the first fret. Not sure what you call them outside of Austalia, but all I mean by scrunchy is an elasticated hair band!!
Sound odd, well it works, the hair band gently mutes all strings except for those you are fretting. Of course you loose the open strings ringing out fully, though they still sound if though they are being palm muted.
Try it, simple and it works. Though I am still gonna buy a tremol-no as they are relitively cheap, and see what there like.
post #14 of 14 (permalink) Old 02-27-2011, 07:47 AM
The open strings ringing out seems like a completely unrelated problem.
You need to work on fret hand muting, pick hand and palm muting as far as I can tell.
eviltwin is offline
floating trems
Floyed Rose locking or free floating trems? big_paul_ski Gear, Equipment, Recording & Off Topic 10 08-05-2009 09:06 AM
i hope this guy gets floating trems going soon. Dragon Slayer J All Other Guitars (including Prestige) 21 06-19-2007 10:01 PM
Ball-bearing the future of floating trems? Arteus Ibanez JEM, UV, JS & Other Signature Models 9 04-02-2007 09:51 PM
String bending (low action) blackpuppets Tech: Setup, Repairs and Mods 12 10-27-2005 03:56 PM
about floating trems and such Jem#5150 All Other Guitars (including Prestige) 10 10-11-2005 07:52 PM
