STUDIO MONITORING: BALANCED TRS vs. RCA OUTPUTS - Jemsite
post #1 of 2 (permalink) Old 06-21-2010, 04:54 PM Thread Starter
Hi Everyone,
I just wanted to ask a question regarding the outputs from my Recording Interface to my studio monitors.
What I currenly have is the Lexicon Alpha USB Recording interface and the MAUDIO AV40 studiophile monitors.
I have the RCA out from the Lexicon ALpha going into the RCA input of my Monitors. I noticed that there are Line Outs from the Interface and I read that these are TRS Balanced Line Outputs. On my Monitors there are TRS Inputs as well.
What I have right now is that the RCA outputs from my Interface goes to the RCA inputs of the Monitors for monitoring.
I just wanted to know what kind of difference will it make if I try monitoring my sound using the Lexicon Alpha's TRS Balanced Line Outputs connected to the TRS Line Inputs of the studiophile Monitors. Will the sound be better compared to that when it's connected via RCA? And what kind of cable should I get? Is it a regular Speaker cable I need to connect them?
Thank you so much in advanced for the help
-Louie
LouieV is offline
post #2 of 2 (permalink) Old 06-21-2010, 08:17 PM
jb4674's Avatar
Reviews: 18
Re: STUDIO MONITORING: BALANCED TRS vs. RCA OUTPUTS
I don't think it'll make that much of a difference but the signal will be a bit cleaner. This is what I currently have hooked up to my Studiophile BX8a Deluxes:
http://www.mogamicable.com/cab_assem...ssemblies.html
Gold TRS-XLRM
Jimmy
jb4674 is offline
Cables 101 - Balanced and Unbalanced Paul_R Gear, Equipment, Recording & Off Topic 3 08-11-2008 11:42 PM
H&K Switchblade speaker outputs Force Tech: Setup, Repairs and Mods 0 11-28-2006 03:55 PM
what's the advantage of having Balanced inputs? Ralph khoury Gear, Equipment, Recording & Off Topic 9 07-06-2006 03:26 AM
Hum when using both outputs on S-2020XAV The Eristic Tech: Setup, Repairs and Mods 3 12-16-2002 01:12 PM
