Syncing 2 delay pedals - Jemsite
post #1 of 2 (permalink) Old 09-22-2012, 01:08 AM Thread Starter
Hello my friends!
I have a question regarding 2 delay pedals (mine are DD7 and DD5) and would like to get anyone's experience on syncing them up using a single tap tempo.
Reading online, I see some people say using a Y splitter actually had their pedal timings drift part after some time. I also see some using these products:
http://www.jhspedals.com/products/guitar-pedals/mini-tap-tempo/
http://www.loop-master.com/product_info.php?cPath=30&products_id=203
Just asking you guys if you have any ideas on this? I'm open to any suggestions!
Thanks and have a nice day!
Bennelsonlim is offline
post #2 of 2 (permalink) Old 09-22-2012, 08:39 PM
Re: Syncing 2 delay pedals
Since you are not using pedals with numeric readouts, the only way to sync them accurately would be to use the products you listed. What delay setting will each pedal be set to when you sync them with the tempo?
One suggestion would be to buy a delay pedal which can send out two delays from a single unit: http://www.***************.com/ampli...-effects-pedal It would simplify your signal chain and probably be more accurate since its coming from one unit. However, as you can see, there is a major price difference.
Formerly Given To Fly is offline
delay , sync , tap , tempo
Chorus and delay pedals ? Armann Gear, Equipment, Recording & Off Topic 11 10-02-2010 11:13 PM
what are some of the best delay pedals with the loudest echo? Rackers Gear, Equipment, Recording & Off Topic 2 09-20-2010 05:07 AM
Using 2 delay pedals at the same time? Mars Volta Gear, Equipment, Recording & Off Topic 12 04-11-2009 01:35 PM
Delay Pedals - getting a good sound Epicus Furor Gear, Equipment, Recording & Off Topic 16 10-07-2006 03:11 PM
Good budget pedals? Delay, Compressor, EQ? DotNetTim Gear, Equipment, Recording & Off Topic 3 05-30-2005 03:08 AM
