T-Rex Chameleon power supply - Jemsite
post #1 of 5 (permalink) Old 07-07-2010, 12:39 AM Thread Starter
This thing is AWESOME. Fits right under the Pedal Train boards, it's quiet, has switches for 9v/12v and even 9v/ 18v on one of them. It even comes with a cable to daisy chain multiple pedals if there aren't enough jacks for all your pedals.
I also love the fact that it can power pedals up to 300ma, which I needed for the T.C. Electronic Nova Delay. The 18v switch was very useful for my Fulltone OCD pedal, too.
Anyway - HIGHLY recommended power supply. I did a lot of research before I bought a power supply and this was the most promising one of out of all of them. I made the right choice.
SnakeEyes is offline
post #2 of 5 (permalink) Old 08-16-2010, 04:59 AM
Re: T-Rex Chameleon power supply
Hi! I have just received my new TC Nova Delay. Can you confirm that the T-Rex Chameleon handles this pedal without any loss of tone?
Terjesen is offline
post #3 of 5 (permalink) Old 08-26-2010, 11:55 PM Thread Starter
I'm sorry that I am so late replying to this. I just saw your question right now.
Yes, I can confirm that the Nova Delay does not suffer for any tone loss when used with the T-Rex Chameleon. The Chameleon powers each pedal up to 300ma and the Nova Delay's manual says that's exactly what it needs to run properly without any loss of tone. I also read somewhere that the Nova Delay doesn't even require 300ma, but more along the lines of 280ma, which is even better.
I highly recommend this unit.
post #4 of 5 (permalink) Old 08-27-2010, 03:48 AM
Thank you so much, I'm ordering the Chameleon today!
Terjesen is offline
post #5 of 5 (permalink) Old 08-27-2010, 06:03 PM
Reviews: 9
I heard a cheeky word from someone on the inside that it'll actually cope with more than it says with no adverse effects. Now I wouldn't go trying this, but it means if you're a little over, provided you're not using hundreds of hungry pedals, it won't make any difference.
The daisy chain is intended for non signal things, like tuners. A tuner's true bypass, and there's no signal when it's on, so it doesn't matter if it picks up a little noise. Using the daisy chain WILL add noise and detract from all that lovely clean power you bought the Chameleon for, lol.
Fun111 is offline
Similar Searches
WTB: Boss PSA-120(Boss normal power supply), or any supply that will work GuitarEvan07 Classified Ads: Guitars and Gear 1 06-03-2009 11:33 PM
BOSS PS-2/CE-3/TU-2/OC-2/T.C. Electronic power supply/MORLEY Power Wah BOOST Sevenstringer Classified Ads: Guitars and Gear 12 05-09-2008 04:05 PM
power supply... chopvai Gear, Equipment, Recording & Off Topic 3 02-24-2008 09:02 PM
FS MXR M-108 10 band EQ with power supply Rudy Classified Ads: Guitars and Gear 0 01-30-2008 12:08 PM
What are you using for power supply? - The guys that use a l carlos seo Gear, Equipment, Recording & Off Topic 9 04-20-2001 06:29 AM
