Tech21/SanSamp - Jemsite
post #1 of 7 (permalink) Old 11-21-2005, 07:50 AM Thread Starter
Talking Tech21/SanSamp
So.. I got a kickass guitar.. but I got a Big Muff Pi which is useless for my style of metal + all strange stuff.. and I remembered a long time ago my friend had a Tech21 Trademark 60. Now, I don't want to buy an amp (the Trademark 10 for example) as I want to go around with it. But I'm having a diffuculty deciding... I'm watering around the areas of a Gt-2 or a Tri-A.C. But which one should I go for? And what's the big difference besides the programmable?
arthurlee04 is offline
post #2 of 7 (permalink) Old 11-21-2005, 09:51 AM
Re: Tech21/SanSamp
What exactly do you want to do with it? Record? Use it as a stompbox? A preamp?
I believe the Gt-2 is considered to be better sounding than the Tri-AC, it's not that good as a preamp for gigs though. I liked the sounds I got from a TM10 a lot, and it is basically the Gt-2 in an amp format. I didn't like the Tri-AC I tried all that much. If you have no need for having 3 tones available at any given time, I would go with the Gt-2.
pawel is offline
post #3 of 7 (permalink) Old 11-21-2005, 10:17 AM
Re: Tech21/SanSamp
Having owned a TM10 (basically a GT2 with a power amp/speaker), I'd highly recommend the GT2 provide you don't need multiple tones at the same time. My biggest frustration with the TM10 at the time was that there was no channel switching capability. So if you only care about one tone at a time, the GT2 should be fine.
You may also want to check out the Behringer GDI-21 ( http://www.behringer.com/GDI21/index.cfm?lang=ENG ), which appears to be a rip-off of the G2 for about $35. I would've been skeptical about it, but I recently bought a BDI-21 and ADI-21 (basically ripoffs of the Sansamp Bass DI and Acoustic DI) and have been extremely impressed by them!!
--B
bduersch is offline
post #4 of 7 (permalink) Old 11-21-2005, 12:11 PM
Re: Tech21/SanSamp
I have tried both and I have a TRI AC now.
Actually, the TRI AC's amp sim sounds better than the GT2, which sounds a little flat.
Main difference between the TRI AC and GT2 would be the voicing. The GT2 is more modern voiced while the TRI AC is vintage. The GT2 is a monster on gain, IMO, no need for boost pedals to achieve crushing death metal gain, and of course, it can do clean, jazz, blues and so on... However, its forte is heavy gain or modern tones.
The TRI AC is vintagey and has little gain compared to the GT2... you need to have a booster pedal to get anywhere close to a tight metal tone. However, it does blues rock and jazz VERY VERY well. Its more responsive/tube-like than the GT2 IMO... and you can get metal tones out of it with a TS9.
In a Live Application, both can plug straight to the PA or whatever amp is there, so you don't need to bring an amp. The TRI AC wins hands down for versatility: you got 3 sounds to play with while the GT2 only has 1 (on/off).
I decided to get the TRI AC because I wanted 3 tones and no amp. I lug around my pedalboard now, and I have the TRI AC set to clean, crunch and heavy. Throw in a ts9 for breakup, heavy blues and metal.
But if you want hi gain stuff, go for the GT2. Btw, the GT2 to the TRI AC to speakers sound ridiculously heavy!!!
Check the sound samples on www.tech21nyc.com to get a better idea of this vintage/modern voicings i described... their sound samples are accurate.
Shredcows is offline
post #5 of 7 (permalink) Old 11-21-2005, 12:11 PM
Re: Tech21/SanSamp
Eh, its you authur! hahaha... okay, didn't really read properly... anyway, you can drop by my place in Tampines to try out the TRI AC. Just PM me.
post #6 of 7 (permalink) Old 11-22-2005, 03:55 AM Thread Starter
Re: Tech21/SanSamp
oOooOo.. haha hey shredcows again! why don't they just make a GT2 with switching capabilities! =P oh well can't always have what you want.. BUT if what shredcows said was true that there is more gain on a GT2.. I'm probabyl gonna get that.. geez.. i should have bought it instead of a Big muff. But the Behringer sounds cool.. I'm gonna go check that out!
post #7 of 7 (permalink) Old 11-22-2005, 03:57 AM Thread Starter
Re: Tech21/SanSamp
oh shredcows, thanks for offer bro. but i dont want to show my shi**y skills around. haha i'm serious. I still need to get good.
boost pedal , death metal , power amp
Similar Searches
FS: Randall RT 2/50 & Tech21 PSA-1 Redwitch Classified Ads: Guitars and Gear 1 12-12-2009 05:52 PM
Marshall AVT or Tech21 TM 60 ?? wareyha Gear, Equipment, Recording & Off Topic 1 06-05-2006 12:32 PM
Those with Jem & Tech21 Trademark 10 rufes Gear, Equipment, Recording & Off Topic 1 10-09-2004 10:16 AM
Tech21 Trademark 10--recommendation - Buy this amp! bduersch Gear, Equipment, Recording & Off Topic 15 02-26-2003 05:07 PM
SansAmp PSA-1 by Tech21 - Does anyone... nuno Gear, Equipment, Recording & Off Topic 4 07-13-2001 07:21 AM
