Technical Question - Jemsite
post #1 of 5 (permalink) Old 12-29-2003, 03:14 PM Thread Starter
Technical Question
My preamp has three outputs on the back. Could someone please explain the difference to me? Does it make a difference which one I use? I'm using a Mesa Boogie 50/50 power amp, if that helps. Thanks in advance.
1) Balanced Line Out (-10dBV)
2) 3V RMS (+10dBV)
3) 1V RMS (0 dBV)
bpd111 is offline
post #2 of 5 (permalink) Old 12-29-2003, 06:35 PM
The balanced is just that. A balanced signal. You will not use that going to a guitar power amp. It's for going into boards with balanced inputs.
The 3v will give you a hotter output and overdrive the power amp more since you are putting more voltage to the input stage of the power amp.
That's the one I'd use.
The 1 V is the weakest signal, but if you don't want any power amp overdrive use it.
What kind of preamp is it anyway???
Gearjunky is offline
post #3 of 5 (permalink) Old 12-29-2003, 07:37 PM
Ice
neat
Another neat thing to do is plug directly into the poweramp.. I never thought of this untill I talked to the guys at mesa and they said that's how they test them at the factory. it gives you tons of clean natural tube tone.
Ice is offline
post #4 of 5 (permalink) Old 12-30-2003, 03:36 AM Thread Starter
It's a Peavey Rock Master - a $100 special. I haven't been able to find a preamp that I'm happier with. My reasoning for asking the question is because I've been using the 3V output and it seems a little noisy, i.e. it's very sensitive to pick noise, scratching, etc. that I don't want to hear. It seems almost to accenuate those noises.
Yep. They told me the same thing when I had some trouble with the amp itself. I need the distortion, EQ, and channels from the preamp though.
bpd111 is offline
post #5 of 5 (permalink) Old 12-30-2003, 05:21 AM
Ice
yea
you ever think it's the power amp and not the preamp that's the problem. Try them at the store through a 290 and hear what the preamp should sound like.
Ice is offline
mesa boogie , power amp , tube tone
Thanks - Technical setup jmlesaux Tech: Setup, Repairs and Mods 23 05-12-2013 07:59 PM
Technical Saber question Nick 6 All Other Guitars (including Prestige) 10 04-15-2008 12:42 PM
Technical difficulties with... er well... Technical Difficulties :) Jaden Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 12-15-2006 09:32 PM
Technical Difficulties AMERICO Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 8 11-12-2006 12:27 PM
A technical JEM7WH question ZaPeRoN Ibanez JEM, UV, JS & Other Signature Models 10 06-30-2005 01:32 PM
