Is there a proper way to break in a CAB? - Jemsite
post #1 of 25 (permalink) Old 06-25-2007, 10:12 PM Thread Starter
I have been told by some tonejunkie's that you should break in a cabinet before cranking it.. i have been told otherwise by other experienced musicians that it is BS and that marshall used to dime amps through them to test them before shipping & selling.. what do you guys think? I have a brand new 1960A beside me, i played it a bit today at a low volume, being cautious.. i have to use it at Jam on wednesday night and we play loud.. what can i do to 'break' the speakers in before then... and is it a neccessity or just a wives tale.
-shogun
shogun is offline
post #2 of 25 (permalink) Old 06-25-2007, 10:23 PM
Re: Is there a proper way to break in a CAB?
I've never hear that a cab has to be broken in. Speakers do, but just playing them will do that, all you're doing is getting the surround used to moving, so move it
bammbamm is offline
post #3 of 25 (permalink) Old 06-25-2007, 10:37 PM Thread Starter
Cool Re: Is there a proper way to break in a CAB?
cmon man obviously i mean the speakers >=|
should it be played at a mediocre - low volume before being cranked?
shogun is offline
post #4 of 25 (permalink) Old 06-25-2007, 11:02 PM
I don't think there is a proper way, but even if there was, it doesn't matter to me, because my speakers sound good, and they have been cranked since I got them.
C.Thep is offline
post #5 of 25 (permalink) Old 06-26-2007, 12:23 AM
Probably the other way around... I seem to recall that there is a little bit of info about breaking in speakers on the Weber Speakers site, and they are frighteningly fanatical about speaker tone!
David McCarroll is offline
post #6 of 25 (permalink) Old 06-26-2007, 04:58 AM
Never heard of working them in before :S
But If I had to I would just work my way up volume wise, then leave em cranked for a few hrs (might be in for a long shift of playing here haha)
wallie! is offline
post #7 of 25 (permalink) Old 06-26-2007, 05:22 AM
I heard you should just max the amp out, clean, and hit chords for about 15 minutes.
dannymills is offline
post #8 of 25 (permalink) Old 06-26-2007, 07:52 AM
Lets all pray he's not married..........................
Josh_P is offline
post #9 of 25 (permalink) Old 06-26-2007, 07:59 AM
Good post. I've heard this too but have no clue if it is true.
I wanted to be a smarta$$ and say "with a baseball bat" but, eh - I'll leave the funny quips to Andy and Cid
screamndemon69 is offline
post #10 of 25 (permalink) Old 06-26-2007, 08:41 AM
jb4674's Avatar
Reviews: 18
Typically, cabs don't need to be "broken in", at least not that I've heard of. Most of the drivers employed for guitar cabinets are not made with the greatest materials on earth like a pair of B&W speakers would, for example.
High-end speakers, on the other hand, sometimes will need to go through a "break-in" period of 50-100 hours of normal playing (nothing loud volume wise) before they sound the way they were supposed to. Typically, audiophiles will make claims that this is something imperative for every speaker but, most speaker manufacturers will not disclose such procedures because they are not required.
I hope this helps.
Jimmy
jb4674 is offline
post #11 of 25 (permalink) Old 06-26-2007, 08:56 AM
yeah i thought you were just suppose to crank head for a few minuets on clean .
j.arledge is offline
post #12 of 25 (permalink) Old 06-26-2007, 09:53 AM
-shogun
Fact is Nigel Tufnel had his Marshall cabinets "broke in" at the factory personally by Jim Marshall by going one better...... 11
jemplayer55 is offline
post #13 of 25 (permalink) Old 06-26-2007, 10:22 AM
Type what you mean.
I deal with people who say one thing but mean another all day, and unless you say what you mean, I am not going to attempt to read your mind.
This is direct from Celestion's site:
How do I break in my speakers?
Important Note! Before breaking it in it's advisable to "warm up" the speaker gently for a few minutes with low-level playing or background hum.
Break in a speaker with a fat, clean tone: turn up the power amp volume to full, and control the level with the preamp gain. Use a level that will be quite loud, but not painful in a normal size room.
Have the bass and mid up full, and the treble at least half. On your guitar, use the middle pick up position (if your guitar has more than one pick up) and play for 10-15 minutes using lots of open chords, and chunky percussive playing. This will get the cone moving, and should excite all the cone modes and get everything to settle in nicely. The speaker will continue to mature over the years, but this will get it 95% of the way to tonal perfection in the shortest time.[
bammbamm is offline
post #14 of 25 (permalink) Old 06-26-2007, 10:24 AM Thread Starter
thanks for the help guys.. what i am gathering is that it is more of a finatic procedure and isnt neccessary, im going to look around on the net a bit but i think i will crank it on clean for a bit and play some country (WOOO)..
another question: as your speakers age, do they sound better, or worse.. ( i am assuming it would be debatable.) is there a preference to brand new speakers?? or are worn speakers what some people look for.. assuming that they still work fine and are not out of phase..
shogun is offline
post #15 of 25 (permalink) Old 06-26-2007, 10:27 AM
Speakers don't change phase as they age.
They either work or they don't, phasing is another issue altogether, having to do with wiring and or miking techniques.
bammbamm is offline
clean tone , nigel tufnel , power amp , preamp gain
what is the proper way to adjust the string retainer? lunarlead Tech: Setup, Repairs and Mods 2 07-31-2006 01:34 AM
How does Vai not break strings? Fry Gear, Equipment, Recording & Off Topic 15 02-25-2004 07:24 AM
Proper way of tuning the JS? DrPuls Ibanez JEM, UV, JS & Other Signature Models 6 11-22-2002 06:46 PM
Break angles to ease string tension. Josh Blagg Tech: Setup, Repairs and Mods 0 03-26-2001 10:38 PM
