Tone issue with band - Jemsite
post #1 of 28 (permalink) Old 05-21-2006, 03:34 PM Thread Starter
Hello, I am fairly new to this forum. I was wondering if I could get a little advice from some of you guys. I play lead guitar in our group and I like to play loud. The problem is that in order to get my tone, my volume is too loud most of the time compared to the rest of the group. I tried turning my 4 x 12 cabinet around to face the wall, but then the tone sounds very "bassy" and solos do not cut through. I place my 4 x 12 cabinet on a couple of milk crates to get the cab off the floor a bit as I find these cabs are very directional. Any other suggestions would be greatly appreciated. We typically play in small to medium sized clubs.
Thanks in advance
Kev
kpinks is offline
post #2 of 28 (permalink) Old 05-21-2006, 03:43 PM
Re: Tone issue with band
Try cutting down on your treble and presence and boost your mids, that way you won't have to turn up so loud to be heard an you'll cut through the mix better.
Epicus Furor is offline
post #3 of 28 (permalink) Old 05-21-2006, 03:46 PM
ScottB's Avatar
Are all of the instruments either miked or running direct in the house mains? Your band will achieve a better overall sound if properly mixed through the PA.
Wether you're in the PA or not, the problem is that your stage volume is too high. Run a separate 1x12 or 2x12 monitor cab from your head and position it pointing up at you, away from the crowd and away from the rest of the band. Turn your amp down until your 4x12 is at a comfortable level for the rest of the band. You'll still be able to hear yourself clearly through the monitor.
ScottB is offline
post #4 of 28 (permalink) Old 05-21-2006, 03:58 PM
You sound like a rocker. I admire you. I also like to play loud.
Find a new band. Find people who are not scared to rock.
Ant1981 is offline
post #5 of 28 (permalink) Old 05-21-2006, 04:15 PM
Reviews: 7
^ LOL!
brothersnowgone is offline
post #6 of 28 (permalink) Old 05-22-2006, 10:58 AM
rgr
Congratulations, you're a rock guitarist...
You might try a Hot Plate or similar, or maybe a 2-12 cabinet so it doesn't move as much air. That way you can still turn your amp up but not be as overpowering.
What kind of amp are you using?
Playing loud is fun until your ears ring constantly.
rgr is offline
post #7 of 28 (permalink) Old 05-22-2006, 11:07 AM
I my last band I used a 4x12 cab, and I got away with it because the others played at hell raising volumes too.
We loved it.
Ant1981 is offline
post #8 of 28 (permalink) Old 05-22-2006, 05:38 PM
Yep, nothing wrong with a bit of loudness!
Though i would suggest boosting mids and cutting down bass if you're scared to loose your hearing quickly
Chud is offline
post #9 of 28 (permalink) Old 05-22-2006, 05:45 PM
Eggy's Avatar
Try an Ibanez Tube Screamer pedal. It'll add the extra crunch that high volume gives you without having to turn up all the way to 11.
Ben
Eggy is offline
post #10 of 28 (permalink) Old 05-22-2006, 06:09 PM
We loved it.
Problem here is that if everyone's just turning up to match the others, the sounds going to sound terrible unless they're playing an open-air stadium with a few feet of separation between them and the audience
Maybe not using a full 4x12 cabinet? Try a 2x12. Also try playing cranking the vol on your guitar and not the amp. Sometimes it responds the same (or better) tonally without using excess volume. +1 on the Tubescreamer by the way - so much tube-warm goodness
ChopTart is offline
post #11 of 28 (permalink) Old 05-22-2006, 06:22 PM
Either that or he needs to leave the 'jazz band' behind and go and find some proper rockers.
Personally, I think he's a fine super guitar man who's dream is to rock and rock properly. You don't piss out of your trousers with your dick half out do you, so why play guitar with the sound half as good as it could be?
Ant1981 is offline
post #12 of 28 (permalink) Old 05-22-2006, 07:25 PM
Kev
What kind of gear are you using? If you are using a tube amp and find that the only way to get the tone you desire is to turn up your amp, think about a power soak, or equivalent. Changing to a 2x12 would probably not give you the desired results as the tonal difference between a 4x121 and a 2x12 is noticable. However, things you can do vary on what gear you are using. Good luck, Tobe
tobe is offline
post #13 of 28 (permalink) Old 05-23-2006, 02:17 PM
Thanks in advance
Kev
I use a THD hotplate, it's not the same as not having anything between the amp and the speaker but the sound is fairly similar and the volume is very manageable.
3rdeye is offline
post #14 of 28 (permalink) Old 05-23-2006, 02:49 PM
rgr
It's good to see that Nigel has found the forum
rgr is offline
post #15 of 28 (permalink) Old 05-23-2006, 03:04 PM
Jaden's Avatar
my solution to this was a 3 channel amp...
easy.
Jaden is offline
ibanez tube screamer , paul gilbert , peavey wolfgang , power amp , thd hotplate , tube amp , tube amps , tube power amp
Really bummed about my tone : ( Please help me Jupiter Gear, Equipment, Recording & Off Topic 18 09-03-2008 07:45 AM
JUDAS PRIEST cover band? -I was asked to help them out jaken777 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 05-16-2006 08:14 PM
Tone Bone Opinions? Chris From Singapore. All Other Guitars (including Prestige) 1 10-10-2005 11:46 AM
Mesa Mark IV vs. Mesa Quad! Please help! Jupiter Gear, Equipment, Recording & Off Topic 12 02-22-2004 06:03 PM
Tone, Tone and more tone!!! sebastian Gear, Equipment, Recording & Off Topic 2 09-30-2002 11:17 PM
