TriAxis users - Jemsite
post #1 of 4 (permalink) Old 07-30-2003, 07:28 PM Thread Starter
TriAxis users
Can you make the TriAxis sound better than these samples? How?
http://www.jim-horne.com/triaxis.html
(I canīt).
Mandrak is offline
post #2 of 4 (permalink) Old 07-30-2003, 10:35 PM
Well, you have to understand that you can only make a Triaxis sound like a Boogie.
Some of the sounds are not that bad, they just sound like they need a great power amp and a little TLC.
Try using a good parametric EQ. It can make a world of difference with a Triaxis. I have a pair of them, one in my main rig, and an extra paperweight. I personally use it for some bluesy/ rock sounds. Never for clean or for super heavy. It just doesn't do those well. I always combine it with a TC Electronic PEQ.
So just give it a little more tweaking, and add a good EQ, and you should get a boatload of sounds.
Gearjunky is offline
post #3 of 4 (permalink) Old 07-31-2003, 12:07 AM
I was dissapointed when I got my triaxis.The stock sounds were not what I was expecting.Then I read the manual.It really helped me understand how all the channels worked and interacted.A little tweaking and I got what I wanted.It won't do clean sounds Like a blackface fender vibrolux,but still has very usable cleans.
musicdr is offline
post #4 of 4 (permalink) Old 07-31-2003, 12:15 AM
Easy my friend. Try double-tracking stuff. Play left channel. Change the tone a little (or don't even change it at all), play the right channel. Put it all together. This totally kicks ass for rhythm tones. Doesn't always work with lead stuff, but lead stuff has to be in the mix to sound good, it doesn't sound all that good by itself. Unless you're Steve Vai in which case you can strum a single note all alone and you'll get better melody going than I can with all 24 frets and 7 strings, but then the tone won't really matter.
microdmitry is offline
power amp , steve vai
WTB Triaxis + 2:90 custom24 Classified Ads: Guitars and Gear 0 06-20-2010 11:01 AM
Seasoned Triaxis users advice to a new user..... Zoso5962 Gear, Equipment, Recording & Off Topic 3 04-06-2004 02:37 PM
Tried a RoadKing and a TriAxis today. Need TriAxis settings! Kremlin Gear, Equipment, Recording & Off Topic 10 05-29-2002 07:34 PM
Triaxis - I want to get one, but can someone help me out? MorbidAngel Gear, Equipment, Recording & Off Topic 11 09-26-2001 08:50 AM
triaxis Roland Schemers Gear, Equipment, Recording & Off Topic 12 07-23-2001 06:44 AM
