TSL 601 Replacement tube - Jemsite
post #1 of 17 (permalink) Old 02-28-2004, 11:55 AM Thread Starter
hey.. i need to replace one of my power tubes in my Marshall. Whats the goin price for a Svetlana EL34 approximately. 10 bucks.. or like 40 bucks.. cause i have no idea.. thanks guys
adamcbest is offline
post #2 of 17 (permalink) Old 02-28-2004, 11:57 AM
No idea what the cost, but AFAIK you should change both powertubes at the same time.
LennyNero is offline
post #3 of 17 (permalink) Old 02-28-2004, 12:19 PM
Most power tubes will be sold in matched pairs or quads. I'm sure that you probably COULD buy singles, but...it's not really recommended. You'd be far better off replacing all of them at the same time.
vaijem777 is offline
post #4 of 17 (permalink) Old 02-28-2004, 12:24 PM Thread Starter
ok well.. i don't have to change all the tubes at the same time right.. as in.. both the power tubes and preamps.. it would be ok just to change all the powe without changing preamp correct??
post #5 of 17 (permalink) Old 02-28-2004, 12:33 PM
It's perfectly fine to just change the power tubes. Preamp tubes don't usually need changed unless you're looking for a different sound or one burns out
post #6 of 17 (permalink) Old 02-28-2004, 09:16 PM
It IS advisable that you re-bias the amp. Some amps are self-biasing or whatever. This amp is not self-biasing as to be expected with most tube amps (unless otherwise stated by the manufacturer(s)). The amp may not perform correctly if you swap the tubes without re-biasing.
Mike 777 Haug
mike777 is offline
post #7 of 17 (permalink) Old 02-29-2004, 12:02 PM Thread Starter
ok guys.. i put new power tubes in the amp sounds much better.. my tone has improved dramatically.. but after about say 20 minutes of playing i still get this bad crackle in the speaker.. doesn't matter how loud the amp is set. it's always the same crackle at any volume. it's not constant. it happens about every 2 seconds for just a a split second. i looked at the tubes i just put in.. they are fine. the preamp tubes are all lit.. not glowing red like some have said can be a sign for bad ones. it seems to me that if i turned the amp volume all the way down that sound would stop.. but it's not.. any idea??? speaker problems?? interference in the wire from the preamp to the speaker. help me out.. i wanna sell the thing and i want no problems with it when i sell it.. thanks guys
post #8 of 17 (permalink) Old 03-01-2004, 01:11 PM
Does the crackle get louder or quieter in relation to the amp volume?
-D
Drew is offline
post #9 of 17 (permalink) Old 03-04-2004, 04:58 PM Thread Starter
no the crackle is at a constant volume regardless if the amp is loud or soft
post #10 of 17 (permalink) Old 03-05-2004, 09:11 PM
I am having the exact same problem... you might actually find that not only are you getting the crackle sound, but you might be getting volume swell problems too. It's especially noticable at louds volumes, where your playing away, and then the volume goes down... for about 30 seconds os so (maybe less), and then goes back up loud again (for 5 second).. and iterates like that..
see this thread: http://www.jemsite.com/phpbb/viewtopic.php?t=29566
Joshka is offline
post #11 of 17 (permalink) Old 03-05-2004, 09:15 PM
also, I want to know (in an effort to fix my case of the same problem), if you use the FX return, instead of the main input (so in effect - bypassing the preamp), do you still use the preamp tubes?
if not, then the problem can't exist in the pre-amp tubes, which could be a good way of trouble shooting a problem like this?
if this is infatc true, then a person experiencing a problem where he/she is unsure about the state of the preamp tubes, they could use the FX return input instead, and then see if the original problem exists?
Joshka is offline
post #12 of 17 (permalink) Old 03-05-2004, 09:20 PM
also, if this was the case (that the preamp tubes did not get used), then if it was your normal setup to use the FX return, then could you take the preamp tubes out completely, and not replace them?
would this work ok?
Joshka is offline
post #13 of 17 (permalink) Old 03-08-2004, 08:20 PM Thread Starter
there are no swells in the volume. the amp crackles even when nothing is plugged into the amp. nothing in the input and nothing in the loop. it also crackles still even when all the gains/volumes of all the channels are completely turned to 0.
post #14 of 17 (permalink) Old 03-09-2004, 02:44 AM
Change the power amp tubes. Should do the trick.
Mr Orange is offline
post #15 of 17 (permalink) Old 03-09-2004, 06:37 PM Thread Starter
i changed the power tubes, not even 2 weeks ago, dramatically fixed the tone but i still get crackles
power amp , preamp tube , tube amp , tube amps
JTM 30 2x10 tube replacement(tube newb) HomeSkiIIet Gear, Equipment, Recording & Off Topic 2 08-03-2008 10:22 AM
Tube replacement Bladerunner Gear, Equipment, Recording & Off Topic 3 10-31-2005 09:41 PM
Carvin Legacy 100W combo Tube Replacement Hiketsu Tech: Setup, Repairs and Mods 4 03-23-2005 06:39 PM
Tube tube tube. Help me out please.. Marshall JCM2000DSL SHsu516815 Gear, Equipment, Recording & Off Topic 29 06-26-2003 04:40 PM
Tube Replacement - VL212 kirk Gear, Equipment, Recording & Off Topic 1 07-19-2002 09:24 AM
