Tube Amp Boost - Jemsite
post #1 of 16 (permalink) Old 07-30-2010, 03:05 AM Thread Starter
Smile Tube Amp Boost
Hey,
I've got some gigs coming up with my band and i have a 30watt class a tube amp combo (Strauss SV-CL30), I play rhythm and lead and for the solos i need a big volume (and maybe gain) boost. I have a Digitech RP80 which i usually use and it works fine but i want to use the raw amp tone (Tubes ). I have a Boss DS-1 but it doesnt provide a volume boost and the amp footswitch doesnt have a boost feature so i was wondering how i could get a good boost for cheap or even free? I also have tried playing my rhythm parts on half guitar volume and it just doesnt cut it when i solo because i like to be loud. A stompbox that goes half volume when you press it would be good. If anyone can help me it would be appreciated.
Cheers
Kyle
goosey is offline
post #2 of 16 (permalink) Old 07-30-2010, 03:27 AM
Reviews: 120
Re: Tube Amp Boost
Clean boost Pedal will do the job. There are a number of them on the market. Go to your local music shop and ask to try out a few. Choose the one that works for you.
LonePhantom is offline
post #3 of 16 (permalink) Old 07-30-2010, 05:08 AM
Re: Tube Amp Boost
One of my friends swears by the Chandler Tube Driver pedal.He plays Beatles and Stones stuff kind of a vintage vibe with Fender Twins and Gibson Sg he loves it.Sounds good to me and keeps things so simple.
corpraider69 is offline
post #4 of 16 (permalink) Old 07-30-2010, 05:22 AM
Re: Tube Amp Boost
A clean boost won't boost your volume if you are using overdrive it will just push the preamp tubes harder and cause more compression. I think you either need a volume pedal or an eq pedal with the volume cut to drop the volume when it is on?
guitarnoize is offline
post #5 of 16 (permalink) Old 07-30-2010, 06:26 AM
Re: Tube Amp Boost
Clean boost in the FX loop. Should work a treat.
skins345669 is offline
post #6 of 16 (permalink) Old 07-30-2010, 07:23 AM
Re: Tube Amp Boost
Just googled your amp specs. You have an effects loop. Place an EQ in the loop and adjust it in an upside down smile (sad) and increase the output level. When time for solo, kick it in.
The EQ set this way will push the mids higher letting you cut through. The output level set higher will increase the output volume.
If you've tried pushing the front end of your amp with pedals and the amp is already overdriven, in most cases all you're doing is further compressing the signal in the preamp. There will be no real noticable volume increase. You'll get more sustain than anything.
A lot of people don't seem to understand this.
On the flip side, if the amp gain were set clean (or if you're on the clean channel), boosting the front will give you an increase in volume. This is because you have headroom which allows a larger signal in (from the pedal) before being compressed.
Have you noticed that on some 2ch amps the dirty channel volume is higher than the clean channel? This is becasue the dirty channel is more compressed than the clean channel.
This is my simple explanation..... maybe others can get more technical.
Blaklynx is offline
post #7 of 16 (permalink) Old 07-30-2010, 07:51 AM Thread Starter
Re: Tube Amp Boost
thankyou for the advice, i was wondering if there was a volume pedal in a stompbox, one that had a single knob and button, with the knob you could set the volume with the pedal on and then when you press the button to turn the pedal off it by passes it. Sorry i also forgot to add that i do use a fair bit of distortion, I play Classic Rock (Guns N Roses, Whitesnake, Ect...)
Thanks for the explanation Blaklynx I completley understand what you mean. Do you think if I used my dirty channel for rhythm then switched to my clean channel and clicked on my DS-1 in for the solos it would work?
goosey is offline
post #8 of 16 (permalink) Old 07-30-2010, 08:42 AM
IbanezFreak777's Avatar
Reviews: 25
Re: Tube Amp Boost
Cant he just use his pedal by turning the drive or gain or distorion down to 1 and use the vol or level to your desired vol boost.. and there you go
IbanezFreak777 is offline
post #9 of 16 (permalink) Old 07-30-2010, 09:46 AM
Re: Tube Amp Boost
Depends if your happy with the DS1's sound/tone running into your clean channel. It would also mean that you have to tap dance twice, to switch to your clean ch and then turn on the DS1 (I assume that's what you have to do).
Isn't it just easier to place an EQ in the loop and only press one switch and retain the drive characteristics of your amp? It's what you want according to your 1st post.
The Danelectro Fish n' Chips is a good EQ and cheap. Many people like it. I have one as well as an MXR 10 band.
Also, an EQ can do wonders for your tone.
Blaklynx is offline
post #10 of 16 (permalink) Old 07-30-2010, 09:54 AM
Re: Tube Amp Boost
Like a clean boost? I suppose you could try it. I think the sound/tone will suffer with any OD/Dist pedal in the loop. EQ's are meant to be clean...what goes in, goes out (boosted/attenuated frequencies) with the core sound of your amp intact.
I've never had success with any OD/Dist pedal sounding great in a loop. They simply don't belong there....... YMMV
Blaklynx is offline
post #11 of 16 (permalink) Old 07-31-2010, 09:19 AM Thread Starter
Re: Tube Amp Boost
I think im gonna put a EQ in my loop, thanks for the advice
Kyle
goosey is offline
post #12 of 16 (permalink) Old 08-01-2010, 04:50 AM
Re: Tube Amp Boost
im having the same problems when using a holy grail verb in my 6505 loop (signal loss)
probly gonna look to get the mxr m109 to boost when doing leads live
WesThrailkill is offline
post #13 of 16 (permalink) Old 08-11-2010, 06:02 AM
Re: Tube Amp Boost
That can be applied only if amp has serial loop (like Fender HRD has). I have an amp with parallel loop and there's no way I can get any volume boost using pedals in FX loop. When I'm using drive pedals on clean channel, I use EQ pedal at the end of the chain with either EQ set flat+level boosted or EQ set mids up+level on 0. On a dirty channel I use vintage Ibanez metal screamer (just one version of TS) with level all the way up, gain on 10 o'clock and I set tone to best match my amp settings. The point is to play rhythm parts with volume pot rolled down a bit so when I roll it off to the max+hit the MSC pedal, I get pretty good mid boost/gain boost and that is in many cases enough to cut through the band...
Jibboom77 is offline
post #14 of 16 (permalink) Old 08-12-2010, 11:06 AM
Re: Tube Amp Boost
DOes your loop have a mix control? It needs to be set 100% wet. My recto has a parallel loop and I usually set it around 80% wet. I don't have any issues.
I can't see how a parallel loop won't give you the boost you need, even if it doesn't have a mix control. The signal is obviously split two ways; one side is dry (direct) and the other side is wet. Boosting the wet side, you'll get an increase in gain which will mix back into the dry side for output to the power amp. An increased signal = more volume.
Am I missing something?
Blaklynx is offline
post #15 of 16 (permalink) Old 08-12-2010, 04:02 PM
Re: Tube Amp Boost
Yes, there is mix control. And I tried to set it on 100%, and there's still no volume boost. The point is in operating amps in return input, they decrease signal if it's too powerful. Some amps loops turn from parallel to serial when mix pot is turned to 100%, but this one doesn't. I think this is set this way to protect poweramp from getting to high input signal.
boost , pedal , strauss , tube , tube amp
Analog Tube plugins for Logic pro, or hardware tube preamp? SilverSurfer2 Gear, Equipment, Recording & Off Topic 3 10-18-2007 07:05 AM
FS MI AUDIO TUBE ZONE & BOOST N' BUFF Rudy Classified Ads: Guitars and Gear 0 04-16-2007 07:38 PM
FS: S.I.B. Fatdrive Tube Boost Pedal CrossingStar Classified Ads: Guitars and Gear 0 09-19-2006 08:58 AM
Tube Works Tube Driver Td-752-es Mosvalve Head Rudy Classified Ads: Guitars and Gear 0 08-06-2005 08:35 PM
Tube tube tube. Help me out please.. Marshall JCM2000DSL SHsu516815 Gear, Equipment, Recording & Off Topic 29 06-26-2003 04:40 PM
