tube question.... - Jemsite
post #1 of 3 (permalink) Old 04-14-2003, 04:01 PM Thread Starter
tube question....
ok, so my Triple Rectifier and I have had a glourious relationship since 99. Recently, it started make a noise that sounds like crackling so Im pretty sure that its time for new tubes [i know, its terrible I waited til now to change the tubes.].
my question is, the store doesnt sell the power amp tubes and I have shows all this weekend that I have to have the head for. If i just replace the 12-ax7 tubes and the 6l6s and not the 54uG, will it still sound fine and shortly after [like, 3 weeks i think they said it would take for those 54UGs to come in] replace them? will this do any damage to my amp?
im new to this tube thingy.
chris state is offline
post #2 of 3 (permalink) Old 04-14-2003, 06:00 PM
I would have said not.... I think you'll be fine as long as the ones you DO replace are in matched pairs (I think this mainly applies to the Power Tubes)
Personally, I would change the 12AX7's first to see if it solves the problem, Then the 6L6's. then the 54UG's when they arrive. You will at least then know which ones are causing the noise!
jaymond is offline
post #3 of 3 (permalink) Old 04-14-2003, 06:48 PM
odds are it's not the 12AX7s, it's your power amp tubes.
~A
anuj is offline
power amp , triple rectifier
Tube amp question no1spretty Gear, Equipment, Recording & Off Topic 15 04-25-2008 03:23 PM
Preamp tube question Guitarist-Jonny Gear, Equipment, Recording & Off Topic 16 10-22-2007 05:01 AM
Tube Question Thrash Gear, Equipment, Recording & Off Topic 2 11-21-2005 08:14 PM
Tube Question... Elysian Tech: Setup, Repairs and Mods 3 12-01-2004 03:35 PM
recto tube question. chris state Gear, Equipment, Recording & Off Topic 4 02-29-2004 12:19 PM
