Tuning down to C... and string guage - Jemsite
post #1 of 10 (permalink) Old 11-06-2007, 12:23 PM Thread Starter
Ok, so I know that if you want to knwo tune down and dont want you neck to warp you need to have a gauge of string that will properly give the correct amount of tension with that tuning, and spring tension. so what Im wondering is what guage do I need if I want to right tension for tuning down to C standard...? Get what im saying? Cant be too much tension or too little. thanks
Devon8822 is offline
post #2 of 10 (permalink) Old 11-06-2007, 12:48 PM
Reviews: 12
Re: Tuning down to C... and string guage
I have my RG550 tuned to standard C... before I started buying single string gauges, I used a string tension calculator Dee referred me to a while ago...
A standard tuned setup with 9s comes out to like <90 lbs of tension.
The logic I was going for was to get the "feel" of 10s for an open C tuning. Anyhow, the tension I got with my setup had @93/94lbs... can't remember the gauge setup atm but it was something like 54, 44, 34, 22w, 16, 11. The turn-out was wonderful... trem angle was correct with 3 springs and they don't feel flabby, just right. Of course, saddle adjustments, neck angle, and truss adjustments were necessary afterwards to make it play like a champ!
I don't have the link for the calculator thing with me but maybe Dee can help..
Reg
reguv760 is offline
post #3 of 10 (permalink) Old 11-06-2007, 03:22 PM
wow. that seems like alot of work. i don't like a lot of tension. i tune to drop C and use GHS 10 1/2. just had to adjust the truss rod a tiny bit and it was good to go.
RickStar is offline
post #4 of 10 (permalink) Old 11-06-2007, 05:48 PM
Excuse my ignorance but whats the difference between open and drop c?. Also, if i need to tune down a guitar, do i need to change the strings for each note (thin ones and thick ones) ?
sebotas86 is offline
post #5 of 10 (permalink) Old 11-07-2007, 12:12 AM
Reviews: 12
it is when you're down-tuning the guitar from standard E... otherwise, I don't have to make any major adjustments after putting a couple hours of "work" into it and changing all 6 strings from this point should take around 10 - 15 minutes... unless I change brand/gauges again.
easiest way I can explain dropped C is an open D tuning with the low E tuned a step lower (from D to C) while standard C is a standard E dropped 2 steps.
changing strings by down-tuning in small steps is personal preference relative to the specific guitar...
i'm such a n00b... an open C tuning is when the open notes are tuned to a C chord....
Reg
reguv760 is offline
post #6 of 10 (permalink) Old 11-07-2007, 12:57 AM
jaxadam's Avatar
FWIW, I use 11's on all of my drop C guitars, and it works great for me.
jaxadam is offline
post #7 of 10 (permalink) Old 11-08-2007, 11:58 AM Thread Starter
mmmm how about that calculator Dee?
so it seems to me that 11s are ideal for C standard, from what i hear? are 12s to much?
post #8 of 10 (permalink) Old 11-08-2007, 07:43 PM
What about Ernie Ball's Skinny Top Heavy Bottom Nickel Wound .010 - .052??? I know it will feel looser, but how balanced would that be? I'm asking because in my country is difficult to find singles, your best bet is a set...and I'm not liking the .011 (Beefy Slinky Nickel Wound .011 - .054 with a .056 instead of the .054) set I have at the moment in my dropped C RG... I need looser high strings and bit less "stiffness" in the bridge...
sleepyone is offline
post #9 of 10 (permalink) Old 11-09-2007, 04:45 AM
i have 11s on my drop C guitar - the low C is a touch too slack but the trade off is that you can do those pinch harmonic vibratos like what killswitch engage do all the time REALLY easily and it sounds MINT.
Tension on the other strings feels close to standard tuning on 9s.
Satchriossi is offline
post #10 of 10 (permalink) Old 11-09-2007, 10:59 AM
I'd reckon 11s or 12s would suit fine for tuning down to C.
Have tried 12s before in standard tuning on a Strat... ouch. Sounded absolutely beastly, gorgeous. Would do it again if my fingers could cope...
'87
Shredder87 is offline
ernie ball , high strings , neck angle , string gauges , string tension , truss rod
string gauge and tuning Axayacatl Tech: Setup, Repairs and Mods 12 02-23-2007 10:06 AM
Yet another poorly mixed song by your truly IbanezroadstarII Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 33 03-16-2006 09:01 PM
tuning a seven string baritone "normal" skattabrain All Other Guitars (including Prestige) 9 11-12-2004 04:34 PM
Bump up string guage for detuning??? Scott Smith Tech: Setup, Repairs and Mods 6 10-25-2004 08:36 AM
guage question - detuning & string guage yoni162 All Other Guitars (including Prestige) 7 03-04-2002 06:57 AM
