US versus European POWER ISSUES!! - Jemsite
post #1 of 12 (permalink) Old 06-20-2010, 06:39 PM Thread Starter
Reviews: 13
Hey guys. Need a bit of advice. Im looking to get a Mesa Triaxis + 2:90 rig. Now I know the American voltage is 120V and 60hz...
in Europe we have 220V and 50hz.
Can someone tell me if I'll have trouble getting the rig to work/work smoothly over here if I buy from the States?
MANY MANY MANY THANKS
custom24 is offline
post #2 of 12 (permalink) Old 06-20-2010, 06:48 PM
Reviews: 120
Re: US versus European POWER ISSUES!!
Apparently some Mesa Boogies are built with dual power transformer setups. Do a search for Mesa Boogie convert 110V 220V, and hopefully you should be able to find some info on it.
I believe that it's typically a simple process for a qualified amp tech. Switch a wire or two, and add a new fuse. That's if your amp has the ability to do it.
LonePhantom is offline
post #3 of 12 (permalink) Old 06-20-2010, 06:52 PM Thread Starter
Reviews: 13
you're a gent. might actually see if there is a Mesa tech around here that would be able to do the switch. I was hoping someone would know off the top of their heads through experience
Google search it is (:
custom24 is offline
post #4 of 12 (permalink) Old 06-20-2010, 06:58 PM
elcid's Avatar
seeing as you will be applying more voltage with less frequency, there's more than a good chance you'll kill the amp.
elcid is offline
post #5 of 12 (permalink) Old 06-20-2010, 07:02 PM Thread Starter
Reviews: 13
I've read across a number of forums that a transformer will do the trick nicely to alter it from 110V to 220V. The frequency apparently doesn't make all that much of a difference. I do know guys using 20/20s using transformers. I'd just like to see if anyone has any experience with both pre and poweramps being used on transformers.
custom24 is offline
post #6 of 12 (permalink) Old 06-20-2010, 07:20 PM
elcid's Avatar
If you use it with a transformer you should be fine.
elcid is offline
post #7 of 12 (permalink) Old 06-20-2010, 07:23 PM Thread Starter
Reviews: 13
fingers crossed.
the price of shipping is RIDICULOUS!!!
custom24 is offline
post #8 of 12 (permalink) Old 06-20-2010, 11:57 PM
A step-down transformer will solve all your problems. I use one with my Mark IV (120v, Australian power is 240v), works perfectly fine, no noise or anything.
The 20/20 is the only current Mesa product with a multi-tap transformer from the factory, they just need a few wires changed around and you can use them without a step-down.
littlephil is offline
post #9 of 12 (permalink) Old 06-21-2010, 07:36 AM Thread Starter
Reviews: 13
it seems a lot of people are using transformers with mesa gear. thats good to hear. thanks phil!
custom24 is offline
post #10 of 12 (permalink) Old 06-21-2010, 08:31 AM
i have the same rig, Triaxis + Mesa 2:50, and I just bout a 1000W step-up transformer, which feeds teh Furman, and the latter feeds all the gear. That's it.
LowYaw is offline
post #11 of 12 (permalink) Old 06-21-2010, 11:24 AM
It's very common to use transformers on Mesa's here. The 60hz/50hz difference is nothing to be concern about. I'm getting a Dual Rectifier in a day or two, of course with a transformer
Sigar is offline
post #12 of 12 (permalink) Old 06-21-2010, 08:28 PM
Everyone uses step-downs because Mesa's are so expensive everywhere but in the US, so they all buy from there!
mesa , triaxis , voltage
Similar Searches
Fakes versus replicas versus customs dcord Off-topic / Miscellaneous 71 07-02-2010 02:23 PM
European Bands bonehead189 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 5 02-06-2009 10:19 PM
Wanted a European JEM gitaarpro Classified Ads: Ibanez JEM/UV Guitars 3 04-06-2008 02:37 PM
European Bands bonehead189 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 14 07-01-2006 10:10 PM
european models sam669 Comments to Ibanez 7 11-26-2002 10:08 AM
