Using an ENGL E570 pre-amp for recording/headphone practice - Jemsite
post #1 of 1 (permalink) Old 08-05-2010, 09:21 AM Thread Starter
Hi guys!
I've fallen in love with some of the clips I heard of the Engl E570 so I was considering one, however my current living conditions prevent me from doing much noise.
95% of the time I'm just practising the guitar at home with my Pod X3 and headphones...
5% of the time I may be recording some stuff to put up on youtube
So I was thinking how to use the ENGL E570. Since I have the Pod X3, I suppose I can connect the Engl pre-amp to the Pod and use the Pod's built-in cabinet simulators and headphones out for silent practice! Will this sound any good or even an improvement over the Pod's own sounds ? I am not 100% sure if the Pod will simulate the power stage or just the cabinet over a pre-amp signal..
I would really like to avoid having to fire up a DAW with a VST Impulse simulator before I can do my daily practice... this would however be acceptable while recording!
Also I heard about this Hughes & Kettner RedBox that takes a direct signal from a pre-amp and simulates the cab and poweramp stages into a line out signal... has anyone tried this thing ? Is it good ?
Also for the time being I'm not considering an Axe-fx
Thanks for any hints
mindwalker is offline
engl e570 , headphones , recording
Axe-FX vs Engl E570 Pre-amp mindwalker Gear, Equipment, Recording & Off Topic 7 08-14-2010 06:09 PM
ENGL Special Edition Preamp E570 lthrbls Classified Ads: Guitars and Gear 2 01-07-2010 11:48 AM
FS: ENGL Special Edition Preamp E570 lthrbls Classified Ads: Guitars and Gear 6 12-23-2009 12:45 PM
Fs: - Engl Se E570 - Framus Cobra - Both Close To New XiwiwiX Classified Ads: Guitars and Gear 0 04-09-2005 12:55 AM
Who makes a small headphone practice system? - Korg, Rockman bammbamm Gear, Equipment, Recording & Off Topic 11 05-01-2001 02:08 PM
