Using a rack processor in a parallel loop?! - Jemsite
post #1 of 4 (permalink) Old 09-24-2010, 10:30 AM Thread Starter
Post Using a rack processor in a parallel loop?!
Hi there!
Basically I want to add effects to my setup in the form of a rack - most probably digitechs gsp1101. (used)
BUT my marshall DSl401 has a parallel efects loop and Im worried i'll get phasing issues. I want to run them so i can swap between the gsp and marshall preamps.
My local tech sys he'll changethe loop to series for about £70 (GBP)
Basically I'm not sure wether to take the risk of buying the rack if i dont know if its going to work and i dont know if with the mod done to the amp whether it will work either...
And ive looked at upgrading amps but something like a jvm combo with the marshall voicing I like and a series effects loop is SOOO expensive!
Any ideas... I may not get any problems at all I guess... is there any way of finding out?
Cheers!
wm172 is offline
post #2 of 4 (permalink) Old 09-28-2010, 11:55 PM
Re: Using a rack processor in a parallel loop?!
I would have it changed. Re verb, chorus, etc will work but effects like trem will not work. But you can always put them in front of the amp if you buy a unit that can be hooked up with the 4-cable method.
Assumer is offline
post #3 of 4 (permalink) Old 09-29-2010, 07:30 AM
You can either run the mix on the FX processor on 100% and use the FX Loop mix to control the amount of effects, or the opposite - run the FX Loop mix/level at 100% and use the processors mix to control the overall mix.
littlephil is offline
post #4 of 4 (permalink) Old 09-29-2010, 01:10 PM Thread Starter
Cheers for the thoughts guys. Im going to try and see if your suggestion works littlephil and if it doesn't and i get phasing issues etc i'll get it modded. Seems like a plan! thanks
wm172 is offline
1101 , digitech , dsl401 , marshall , tc electronic
What is the best valued Rack Guitar Processor? FarBeyond Gear, Equipment, Recording & Off Topic 3 05-15-2010 09:53 PM
guitar effect processor rack chopvai Gear, Equipment, Recording & Off Topic 1 08-13-2005 06:00 AM
WTS: Alesis Quadraverb 2 Rack Effects Processor toshiro Classified Ads: Guitars and Gear 2 07-22-2005 06:35 PM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear, Equipment, Recording & Off Topic 5 02-13-2002 09:55 PM
Oberheim GM-1000 processor - Multi effect rack thing Fluke Gear, Equipment, Recording & Off Topic 5 12-07-2001 05:36 PM
