V-Amp 2 problems - help needed. - Jemsite
post #1 of 8 (permalink) Old 04-24-2003, 12:50 PM Thread Starter
Hi there.
This may sound a bit stupid but how do i connect my V-Amp 2 to my PC ?
I just wanna play it through my speakers.
And do i need 2 leads for the LINE OUT LEFT....and RIGHT ?
If someone could get back to me it would be a great help.
Thanks.
the.godfather
the.godfather is offline
post #2 of 8 (permalink) Old 04-24-2003, 01:04 PM
2 leads or just use the stereo headphone out. Should be an easy adapter/cable combo from 1/4" stereo to 1/8" stereo.
JESTER700 is offline
post #3 of 8 (permalink) Old 04-25-2003, 07:40 AM Thread Starter
I am pretty sure that i need a MIDI to GAMEPORT cable.
Can anyone back this up?
thanks.
the.godfather
post #4 of 8 (permalink) Old 04-25-2003, 09:45 AM
rfb
Nope. You need that if you want to use the PC interface to edit sounds and so on, or to back up your patches. Just to play through and record on the PC, the midi doesn't come into it. What you probably need is a two-1/4" to one 3.5mm stereo cable (that's prbably what your soundcard has for line input).
- rfb
rfb is offline
post #5 of 8 (permalink) Old 04-25-2003, 09:58 AM Thread Starter
Does it have to go into my soundcard or can it go straight into a PHONE or MIC socket on my speakers ?
Because as far as i am aware my speakers are plugged into my soundcard i think - but it doesnt matter i can unplug them.
And where would i get that cable from ?
post #6 of 8 (permalink) Old 04-25-2003, 10:47 AM
rfb
That should work, yeah.
A music shop? I don't know, really. I know that StudioSpares sell them in the UK.
You may find it easier to get a 3.5mm stereo jack to to phono jack cable, and then some phono to 1/4" adapters. Both of those are quite readily available in Maplin's here, so you could try the equivalent wherever you are - Radio Shack, maybe?
Or you could buy a cable and some plugs and get the soldering iron out...
- rfb
rfb is offline
post #7 of 8 (permalink) Old 04-25-2003, 10:47 AM
You should be able to get the adapters at any electronics store...then just stick them onto your guitar cable...
You should be using this to plug into your soundcard:
http://www.trianglecables.com/35minstermal.html
As far as i know you should be plugging into the Line IN on your soundcard (speakers would be plugged to the line out wouldn't they?)
pawel is offline
post #8 of 8 (permalink) Old 04-25-2003, 11:06 AM Thread Starter
Thanks guys for all the help.
I have just rang one of my old friends i know who is a television and hi-fi repair man, and he owes me a favour.
I told him everything you said and he said he will make me a lead with two two-1/4" and one 3.5mm socket on the other end.
I am useless with a soldering iron - he however is rather useful.
Thanks Guys.
The.godfather
Problems With Veneer. Help needed!! Scarified_pr Tech: Setup, Repairs and Mods 24 09-03-2012 07:50 PM
pc problems help needed rob777vdy Off-topic / Miscellaneous 1 12-07-2008 08:05 AM
my rg3120 problems/needed adjustments Chritar All Other Guitars (including Prestige) 3 12-30-2007 09:40 PM
Problems with my RG550...help needed... Megadeth7684 All Other Guitars (including Prestige) 38 01-05-2007 03:40 PM
Rg 3120 Problems. ANNOYING PROBLEMS!!!! Given to Fly All Other Guitars (including Prestige) 20 05-24-2003 01:24 PM
