Volume Pedal that will NOT affect tone AT ALL! - Jemsite
post #1 of 14 (permalink) Old 04-08-2003, 12:36 AM Thread Starter
Hey ppl, I'm looking for a volume pedal that won't color my tone AT ALL. I don't mind it introducing a little noise as long as my tone is still there. If you know my rig, then you know I'm completely hardnosed in my stance. Money is not a concern.
As a metric for what I'm after, when the volume pedal is set to be all the way up, it should sound as tho you aren't even using a volume pedal.
Thanks, Rich
mechanyx is offline
post #2 of 14 (permalink) Old 04-08-2003, 02:55 AM
what volume pedals have you tried till now? which one gave you this problem?
nuno is offline
post #3 of 14 (permalink) Old 04-08-2003, 09:50 AM
Get an Ernie Ball.
It's direct wired. If you feel the need, you can always upgrade the internal wiring to heavier guage wire.
Don't forget your George L's cables if you want true sound.
Gearjunky is offline
post #4 of 14 (permalink) Old 04-08-2003, 11:35 AM
I second the Ernie Ball. Stay away from any that require power (Morley). I have both and the EB is transparent.
oooo is offline
post #5 of 14 (permalink) Old 04-08-2003, 02:32 PM
It was my understanding that an EB pedal gave a slight boost when it was nose down... or is that adjustable?
-Drew
Drew is offline
post #6 of 14 (permalink) Old 04-08-2003, 11:20 PM
Mine doesn't. You can adjust the taper, and I'm sure it wouldn't be a problem adjusting where the pedal throw ends on the pot. Seems like a really simple mechanical design.
Anybody else notice if theirs has a boost effect?
oooo is offline
post #7 of 14 (permalink) Old 04-10-2003, 01:40 AM
No boost; it's passive. The max it can give is 'no loss'...
I have two; I use them as expression pedals for wah and volume - they're built like tanks.
(Tested 'em out as regular volume pedals first, to make sure they were working as intended, then hooked 'em up to the Bradshaw controller. Nice as expression pedals.)
steve is offline
post #8 of 14 (permalink) Old 04-10-2003, 02:09 AM Thread Starter
Cool, I guess I'll try and snag an EB.
Anyone have any experience with any less mainstream pedals?
Thanks, Rich
mechanyx is offline
post #9 of 14 (permalink) Old 04-10-2003, 11:48 PM
Steel players and a lot of country cats use Goodrich pedals... They're very high quality, low profile volume pedals, built like tanks, utterly transparent, and maybe the only production volume pedal I've ever seen that is better than an Ernie Ball... Personally, I have an Ernie Ball on my board, and am perfectly happy with it, but the Goodrich pedals seem to have a smoother taper that allows for a little more movement (read: more control) for smoother volume reductions... They're pricey though, and you'll almost certainly have to order one.
Jimi D is offline
post #10 of 14 (permalink) Old 04-11-2003, 01:17 PM Thread Starter
Wow, these Goodrich pedals look amazing. Does anyone have any experience using the 1 in and 2 out setup?
Thanks, Rich
mechanyx is offline
post #11 of 14 (permalink) Old 04-11-2003, 01:37 PM
I have a Goodrich L-120. It is really cool because it's really low profile and has a great sweep. The only reason I didn't use it in my main footboard is that I needed the jacks to come out the front of the pedal to keep my footboard dimentions.
I use it all the time when playing through a head or combo.
I bought mine mint condition down in Georgia at a pawn shop for $20, but from what I've seen they are close to $250 new.
If I put it side bu side with the EB, there is no sonic difference, just a different feel.
post #12 of 14 (permalink) Old 04-11-2003, 01:41 PM Thread Starter
Yeah, some places charge that much. I've found the 120 new for about $130 and the 10K new for $175. I think I'll buy several and just sell the ones I decide not to use.
mechanyx is offline
post #13 of 14 (permalink) Old 04-11-2003, 01:47 PM
Does Goodrich have a Web site with more info? I can't seem to find anything.
darren wilson is offline
post #14 of 14 (permalink) Old 04-11-2003, 03:10 PM Thread Starter
If they do, I wasn't able to find it either. I actually had to email an actual 10K owner to find out if it had the same 1 in 2 out setup that the 120 has as all the vendors seem to just post stuff that sounds like it came out of a brochure. He told me that it did have the same setup. I'd never heard of the company before yesterday. I'm imagining there is very little info readily available.
mechanyx is offline
ernie ball , expression pedal , expression pedals , volume pedal , volume pedals
Does the Vine affect tone? cm_17 All Other Guitars (including Prestige) 41 12-15-2012 11:46 AM
Why does wood affect electric guitar tone? GroovyTubes Gear, Equipment, Recording & Off Topic 57 09-07-2012 10:51 AM
Stainless Steel frets affect tone?? power freak Tech: Setup, Repairs and Mods 14 09-28-2009 07:39 AM
AANJ vs BNJ - Affect tone or sustain? YngVaiTriani Ibanez JEM, UV, JS & Other Signature Models 20 09-17-2001 05:20 PM
Expression Pedal? - which volume pedal will work? mikek Gear, Equipment, Recording & Off Topic 1 01-02-2001 07:39 PM
