Wampler clear buffer with switch review... - Jemsite
post #1 of 1 (permalink) Old 07-29-2011, 01:44 PM Thread Starter
I recieved this pedal, the wampler clean buffer.
I needed a solution because my sucking tone problems since I left all my rack stuff and went back to pedals... So, I needed a buffer to change the signal to low impedance. I'm using this pedal as the first in my chain.
What a difference in the tone when is on, I'm using dimarzio braided cables and dimarzio braided patch cables, and only 6 pedals more (all true bypass)
The sound is like hi-fi, my amp back to life and my distortion pedals sound better than ever, the triple wreck sounds even more awesome than before and I still can't believe it. I was using an EQ pedal for a quick fix of this but now I don't need it anymore, I use it as a volume boost now.
I know wampler don't make this pedal anymore, but is so good that I needed to say it to you guys.
cheers
Vintage_freak_forever is offline
buffer , sucking , tone impact
NPD--Wampler goodness! AlaskaBat Gear, Equipment, Recording & Off Topic 10 06-27-2011 11:17 AM
WTB: Wampler Pinnacle II Pedal piranha Classified Ads: Guitars and Gear 0 11-24-2010 02:15 AM
FS: Lovepedal Mini Buffer waylay00 Classified Ads: Guitars and Gear 5 06-20-2008 12:40 AM
Audio Buffer Talk.... chopvai Gear, Equipment, Recording & Off Topic 5 05-26-2008 10:36 AM
Best 12AX7 for effects buffer? kent Gear, Equipment, Recording & Off Topic 1 03-30-2004 11:26 AM
