Where to get a low-wattage poweramp? - Jemsite
post #1 of 20 (permalink) Old 09-03-2007, 05:57 PM Thread Starter
Hey guys,
Just ordered a Ultra+ modded ADA MP-1, gonna be great! Anyway.. For the moment I only own a cheapo marshall combo, and I'm going to use it's poweramp section until something better comes up.
Uh.. I don't have the slightest clue what poweramp to use for this purpoise, but as I'll mostly play it at home, and still want to get the cranked-up tube-sound from the poweramp section, I thought that maybe it's best if I try to find a low-wattage one. I haven't really seen anything lower than 50 Watt stereo, which still is way too high to be called, well, low.
Well, sure I have seen poweramp sections of combos lower than that, like the Cornford Carrera with it's.. What, 8 watts? But is there a separate rack-poweramp that's low wattage? I'd love to get some answers for this.
Thanks in advance!
Fabio is offline
post #2 of 20 (permalink) Old 09-03-2007, 06:01 PM
elcid's Avatar
Re: Where to get a low-wattage poweramp?
Mesa makes a 20 watt one, Im sure it's expensive, but that's the only one I've heard of.
Maybe you can use just the power amp section of an Orange Tiny Terror, I think it's switchable between 7 and 15 watts
http://www.mesaboogie.com/Product_In...20_stereo.html
elcid is offline
post #3 of 20 (permalink) Old 09-03-2007, 06:37 PM
Reviews: 120
Unfortunately the Tiny Terror doesn't have an effects loop. Only thing that would hold me back from getting one.
LonePhantom is offline
post #4 of 20 (permalink) Old 09-03-2007, 06:37 PM
Somebody makes an all - tube power amp for an iPod - about 5 watts a side - not cheap, but cheaper than a Mesa 20/20.
Mind you anyone who uses a 20/20 swears by them! They are by all accounts mind - bogglingly loud!
David McCarroll is offline
post #5 of 20 (permalink) Old 09-03-2007, 06:38 PM
Shouldn't be hard to get one added by a decent amp tech - I'd be kind of surprised if there isn't already a TinyTerrorTweaking forum on the net by now.....
post #6 of 20 (permalink) Old 09-03-2007, 06:42 PM
elcid's Avatar
I still want one, My AD30HTC doesnt have one either, but I wouldn't trade that amp for anything.
elcid is offline
post #7 of 20 (permalink) Old 09-03-2007, 11:18 PM
Reviews: 120
I thought about that, how much do you think that would cost to get done? If it's a couple hundred I'd definitely be interested.
post #8 of 20 (permalink) Old 09-04-2007, 11:28 AM Thread Starter
Ah.. So that means my theory of getting low-wattage poweramp only to be able to crank it up and still have it at respectable volumes is faulty?
What I thought was that I would possibly be able to get the cranked-tube-sound at lower volumes, is this like totally wrong? :P
I thought I'd figured this out after all these years..
Fabio is offline
post #9 of 20 (permalink) Old 09-04-2007, 02:31 PM
20 watts is still loud as hell when cranked. If you want to crank it at bedroom levels, you're going to be looking in the range of 1 to 5 watts.
Martyr Machine is offline
post #10 of 20 (permalink) Old 09-04-2007, 04:36 PM Thread Starter
Ah, true.. Anyone? 1 watt poweramp? Home made? I'm willing to try out your home-built poweramp made of beer cans, dutch tape and steel wool, as long as it's tube-driven
Though, I just got my eyes on a ADA microcab, or even better, I'll try to mod it to a monstercab..
Anyway, feel free to chime in if you've heard of some, I dunno, brazilian made 5 watt poweramp somewhere.
Fabio is offline
post #11 of 20 (permalink) Old 09-04-2007, 04:40 PM
I know the Orange Tiny Terror can be cut down to 7 watts, and the Mesa Lone Star Special can be cut down to 5. You might try the poweramp from one of those. The Tiny Terror can be found for less than $500
post #12 of 20 (permalink) Old 09-04-2007, 04:45 PM Thread Starter
Thanks, I'll check it out..
Fabio is offline
post #13 of 20 (permalink) Old 09-04-2007, 06:53 PM
Reviews: 120
Maybe also check out the Peavey Windsor Studio combo amp. 15-20W adjustable. Has an effects loop and it's designed to handle a multitude of different tubes.
http://www.peavey.com/products/brows...)%20Studio.cfm
It's supposed to be modelled after a modded JCM800 which is what really interests me. As soon as I can have the funds together I'm testing it out and getting one probably.
post #14 of 20 (permalink) Old 09-04-2007, 08:35 PM
elcid's Avatar
My Valve Jr is 5 watts into a 1X10 cab and its still over bedroom loud when cranked
elcid is offline
post #15 of 20 (permalink) Old 09-04-2007, 11:14 PM
Yep. Crank that badboy in your bedroom, and your amp will be alone in the room.
Enjoy: http://zvexamps.com/
If anyone calls/e-mails for prices on either Zvex amps post 'em here will ya?
bpd111 is offline
combo amp , david mccarroll , power amp , steel wool , tube power amp
your pre amp and poweramp output settings shredmaster Gear, Equipment, Recording & Off Topic 3 06-27-2005 06:30 PM
Low wattage valve combos Jammy Gear, Equipment, Recording & Off Topic 53 08-25-2004 09:16 PM
Low wattage and high gain - its nearly here! Jammy Gear, Equipment, Recording & Off Topic 7 08-05-2004 09:21 PM
PA passive cabs... wattage problem... NickFlyMan Gear, Equipment, Recording & Off Topic 6 11-26-2002 06:25 PM
Poweramp to POD Pro - Mesa 20/20 or some other furthur Gear, Equipment, Recording & Off Topic 3 07-30-2001 12:37 PM
