2 active 1 vol 1 tone 1 8pole switch help - Jemsite
post #1 of 4 (permalink) Old 02-24-2014, 08:44 AM Thread Starter
Hi I'm new here and have an issue wiring my s prestige. I believe it is a 2004. I have a couple questions.
1. The new pickups (Dave mustaine livewires) supply 100k pots and caps. The original has 500k pots and 2 separate caps for each pot. I can find out exactly what they are but question being should I replace them or keep original design?
2. Originally the neck humbucker is split with 2 outputs and bridge only 1 so how do I wire my new set which only has one output. The 8 pole switch's original design seems to take both output and ground from neck and bridge pick up. Also some terminals are jumped. How does this switch work and what's the best configuration?
Finally I am playing a lower B standard tuning with 64-13 strings. Not sure if this helps evaluate the pots/caps . Thanks for the help ahead of time.
jimseekford is offline
post #2 of 4 (permalink) Old 02-24-2014, 04:18 PM
Reviews: 120
Re: 2 active 1 vol 1 tone 1 8pole switch help
Yes you need to use the pots that come with the pickups. You can't split these actives like you would the stock passives.
It will also be easier to get a standard Fender style three way switch too. You won't really be able to wire the pickups you have on a standard five way without dead spots on the pickup selector.
LonePhantom is offline
post #3 of 4 (permalink) Old 02-25-2014, 08:45 PM Thread Starter
Thank you for taking time to answer my questions. I will hopefully going to get this fixed soon.
post #4 of 4 (permalink) Old 02-25-2014, 11:56 PM Thread Starter
I got it wired with the original switch. It sounds good to me.
I can't post links but it's on my YouTube
Search jim seekford and there's a video of how I wired it
s predtige
Looking for Ibanez Yellow Vol Tone & Switch Tip sebastian Ibanez JEM, UV, JS & Other Signature Models 3 10-18-2011 12:18 PM
2 hum, 1 vol, 1 tone, 5 way switch GUITARMAGEDDON Pickups & wiring 4 07-28-2011 05:29 AM
FS: INF3, INF4 with switch/vol/tone. Almost new. Stygian Classified Ads: Guitars and Gear 1 09-07-2008 01:03 AM
WTB: RED Voluime/Tone/Switch Cap caprile Classified Ads: Guitars and Gear 4 03-23-2008 10:34 AM
